What to dig post holes with in rock?
/ What to dig post holes with in rock? #22
Commonly referred to as a post bar, crowbar, digging bar, spud bar, fencing bar or a blister raising shoulder aching sob.
And in Kentucky, just "Digger Bar," and probably why all of us in our seventies have arthritis in our hands...
/ What to dig post holes with in rock? #23
How are you attaching the post to that base?
Galvanized carriage bolts thru a 4x4 treated post or metal T post, whichever I'm using.
/ What to dig post holes with in rock? #24
About 1/4 of all my T-145 steel posts required a hole drilled in bedrock. That was 150 holes - +/-. My neighbor has a commercial air driven jack hammer. It bores 2" holes, very quickly, in the bedrock.
I will and do use t-post but I still have to have some wood post for gates and corners. I typically do rent a compressor and drill to put t-post in.
I have thought about hiring it done but am normally of the mindset to do it myself and use that money to buy more tools.
/ What to dig post holes with in rock? #27
Haven't heard it called that before. I have a couple of them and they have put a lot of post in the ground, both digging and tamping. They don't do anything in blue limestone.
I just crack the rocks with the blade side, or pry them out if they’re small enough. Even had someone hold the bar like a chisel, and I hit the blunt end with a big sledge.
If it’s a BIG rock or boulder, it doesn’t matter what you use. No auger will got through it.
/ What to dig post holes with in rock? #28
I don’t think it’s practical to try busting through the thick layer of limestone in middle TN with any hand digger bar. Usually it’s 8 to 12 inches thick with another layer below it.
/ What to dig post holes with in rock? #29
The old homesteader never fenced all 80 acres. There are areas where solid bedrock is close to the surface. Boring a hole in bedrock with a sledge hammer and bar would not be my idea of fun.
It's taken me and my neighbor - with his commercial jack hammer - many years to get all the fence tripods replaced with actual T-posts. We would do a few every year.
/ What to dig post holes with in rock? #31
Trust me Hay Dude - you NEVER want to find out either.
I have one on the back of my truck and use it all the time
/ What to dig post holes with in rock? #32
It took ~ 660 T-145 steel posts to surround my 80 acres. It's a "pure" rectangle - 1320x2640. About 165 of my "posts" were wooden 2x4 angles. Due to bedrock. Slowly but surely - with the help of my neighbor and his commercial jack hammer - all my wooden "posts" have been replaced with T-145 steel posts.
My four wire - barbed wire - fence was, and still is, stretched tight. This allowed the wood "posts" to work pretty well.
These "posts" were simple. A 2x4 flat on the ground. A vertical 2x4 attached to the flat one. A 2x4 running at a 45 degree angle and attached to both the flat and vertical ones.
I would cut all the 2x4's to the correct length - transport them with the tractor. Assemble them - raise the barbed wire, one wire at a time and attach to the wooden "posts".
Many times the neighbors cows would be there to watch. I don't think they ever understood that they were being fenced OUT.
There is a new property owner - right across the county road from my driveway entrance. He came to talk to me the other week. He got an estimate on installation of a four strand barbed wire fence around his 20 acres. He was in a state of shock. I told him he could always due it like I did.
As I remember - all the rolls of barbed wire ( 26 or 28 ) and the 660 T-145 steel posts - cost a total of around $5800. Buy in bulk and save some money.
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
Mini drum mulcher (A61567)
Mini drum mulcher...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
