   / Your last generator Maintenance Run
EVs have their place, and can suit certain people's local needs, but the Run Till Dry approach some people used with ICE engines creates bigger problems - in fact, with large (commercial) applications, if the battery pack is run-down below a certain level, it can void the warranty.
A guy @ work knows an MD, who drives a Tesla, and her daughter drives a second one the mother paid-for. He said they are often on a tow-hook - I asked what failed, the answer was "Just a run-down battery". He said he wasn't surprised @ the spoiled daughter doing that, but was a little surprised that his friend the doctor kept doing the same.....
Yep, hard to beat the immediate utility of a can of 5 gallons of gas or diesel..... in an engine that burns it...... Consciously or not, many people have been conditioned by that ^ fast Life-Line present in ICE engines.
Rgds, D.
   / Your last generator Maintenance Run #7,192
Yesterday, the generator at my mom’s didn’t start when the power went out. 3F and the battery was shot. Jumped it with my truck to get it going, then picked up a new Die Hard Silver at advance. Went up today and swapped that out. Changed the oil and filter too, as I didn’t get it done this fall. 2 quarts of Mobil 1 and an oem generac filter. Should be good for another 2 years.
Generator worked fine earlier this month when the power went out, but it wasn’t as cold. Not sure how old the battery was. Possibly the original from 2012? I don’t remember ever changing it before. If it was, it was way overdue.
   / Your last generator Maintenance Run #7,193
A generac air cooled should only take 1.7 qts of oil. Dont overfill it
Time does Fly, doesn't it :cool:.
A quick Save for Mom, and a useful Holiday present !
Best Wishes to All for the Holidays.
Rgds, D.
   / Your last generator Maintenance Run #7,195
1.9 quarts for the 17kw. 2 qt. is close enough. Measures just right on the dipstick.
   / Your last generator Maintenance Run #7,196
Thats strange, i service over 300 air cooled generators and there either 1.1, 1.7, or 2.2 qts. But as long as it shows ok on dipstick your good to go.
   / Your last generator Maintenance Run #7,197
I have serviced a bunch over the years. Mostly generacs. Even the older steel enclosure 12kw & 16kw were always happy with 2 quarts. The Briggs powered Cummins/Onans were something like 80 oz.
One of my customers just had a Taylor 30kw installed. Perkins turbo diesel powered. Not hooked up yet, just sitting in place. It’s in a special room in the crawl space. This Taylor replaces a Kohler unit from the 80’s that developed a smoke problem. He threw parts at it to the tune of 10 g’s before deciding to replace. That one had a 4239 Deere engine. It was a noisy beast.
Ouch.... just Parts today runs up a bill fast; sad when it doesn't play-out.
Sounds like you are fine on Oil. When I got my 7kw Briggs, it was the first one I've had with a screw-in dipstick. The delta is minor, but to help me sleep @ night :cool: , I labelled it, as you can be off by the height of the threads.
Automotive electronics (modern) can get funky with batteries much older than 5 years, at least in this climate here. We had a chat in this thread a while back...... can't recall exactly, but I think grs's ballpark on typical Generac battery's life was near there...... any which-way you play it, In-Service Date on a battery is Good To Know !
Rgds, D.
   / Your last generator Maintenance Run #7,199
what would it cost to have a real dipstick instead of the screw in cap?
if the unit isn't perfectly level, readings are not very exact
I miss a dipstick.
I also miss an oil pump and an oil filter.
current setup to me not very robust.
   / Your last generator Maintenance Run #7,200
I’m sure that setting a generator level, corner to corner to corner, is imperative whether equipped with a dipstick or screw cap/dipstick.
Yes, a fully pressurized lube and filter system would add significant cost to a small engine. But if Honda GX small engines can last for thousands of hours with regular maintenance, why bother?! It proves that quality design and build really matters…
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2023 yamaha (A55758)
ASV RT-120 POSI TRACK SKID STEER (A52709)
ASV RT-120 POSI...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle All-Terrain Crane Truck (A55973)
2013 Peterbilt 367...
2012 International Prostar (A56435)
2012 International...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
