Your last generator Maintenance Run
   / Your last generator Maintenance Run #7,201
When I got my 7kw Briggs, it was the first one I've had with a screw-in dipstick.
My old Coleman had a BS engine with the screw in dipstick. Everything else I owned you just put the dipstick in, unscrewed, and read the oil level that way. I realized my mistake when it started smoking after running about 5 minutes and soaking the air filter. Amazing what you can learn when you read the manual LOL.
I’m sure that setting a generator level, corner to corner to corner, is imperative whether equipped with a dipstick or screw cap/dipstick.
Yes, a fully pressurized lube and filter system would add significant cost to a small engine. But if Honda GX small engines can last for thousands of hours with regular maintenance, why bother?! It proves that quality design and build really matters…
Changing the oil..... on the small stuff, even people that know better, can tend to ignore small utility equipment.
Since much of this equipment takes hardly any more that 1 L/quart, it not a $ issue.....
Rgds, D.
At the risk of Losing Their Man-Card..... Real Men Don't Read Manuals !!!
It works fine as a dipstick on my 7kw BS, but your story illustrates what introducing that variable can do. At least on yours, the result was highly visible - as opposed to an overfilled non-smoker, that ended up running on aerated oil for xyz hours.....
Devil, meet Details..... :cool:
Rgds, D.
   / Your last generator Maintenance Run #7,204
Rgds, D.
The problem with reading manuals is that sometimes the manuals are written by someone who shouldn't have been a technical writer in the first place.
I have seen multiple maintenance and operation manuals over the years written with errors. One error that cost the manufacturer millions of dollars in warranty repairs, just because the oil specified for an in line oiler was the wrong type.
Having good training and common sense to use that good training trumps reading a manual in a lot of cases.
"Real men do read maintenance and operation manuals"!
   / Your last generator Maintenance Run #7,205
if the unit isn't perfectly level, readings are not very exact
This comes down to design. A bad design with the dipstick in the corner of the pan, will be badly affected by measuring on an un-leveled surface. But if dipstick is aimed toward middle of the pan, then small errors in machine leveling won’t have as much effect on measured oil level.
   / Your last generator Maintenance Run #7,206
Not necessarily a bad design though. A generator with an oil level sensor also needs to be level for the simple reason to detect the proper/safe oil level or it will shut down or not shut down as required, in order to save the engine…
:) I didn't take the time to find a Heavy Sarcasm emoticon in that post....
To your point about Tech Writing (altho, IMO, it applies much more broadly than that)..... modern "communication" doesn't help this issue. In the Olden Days..... a Printed document/book/catalog typically had much more editorial-review, before going to press <--- was there Never any mistakes, No, but IMO, less than today's documentation..... as long as the Safety/Liability Warnings @ front of document gets signed-off by Legal, it seems what follows gets less attention.
IIRC, it was MercBenz who ended up replacing a # of gas motors in cars.... that was back-when port fuel-injected engines were pushing waaaayyyyy out on OCI, and they didn't spec the oil correctly in the Owner's Manual. (and.... Canadian Winter is usually classed as Severe-Service, under most Manuf olde-school MTCE categories).
Agreed..... it's All Data..... pull it in from various sources (on anything critical.... but the problems can set in when you don't realize What is Critical), cross-check, and plan your MTCE.....
When I'm chasing oil data (or, it's just a long Canuck Winter, and I've run out of things to read) I will spend some time on BITOG (Bobistheoilguy), looking at relevant oil analysis reports, both New and Used. I'm a bit of an oil-geek, but spending time on there can be somewhat like taking a juvenile deliquent on a tour of an active Jail..... Joking aside, BITOG has good info to wade through, esp. on new/emerging problems @ a specific engine level.....
He has others I like, but this is one of my favourite Will Rogers quotes
A quote by Will Rogers
(Re-post by me, but I'm a slow-learner, and need to be reminded about that electric-fence often.....)
Rgds, D.
   / Your last generator Maintenance Run #7,208
having generator envy?
your gen just not putting out enough?...
now you can buy a new Ram pickup and also have the biggest
generator of them all.
real bragging rights too, 130kw.
Ram's new "hybrid" is all electric, and a standalone generator powered by
their 3.6 V6 engine. Just like heavy equipment and trains.
want to power your house?
wonder if you can tap into that 130kw...
let's see, V6 engine generator maintenance
this should get interesting :giggle:
Dave, start studying OBD codes....
   / Your last generator Maintenance Run #7,209
you need to run it for awhile on a hot day and see what the exhaust temps are around the wood. me, id feel better if that was metal support, like my fireplace uses.
I'd also suggest doing the same hot day load test with the generator at or near full load: Diesels get a lot of cooling from excess combustion air when running lightly loaded.
   / Your last generator Maintenance Run #7,210
Our new MG4 can output around 7kW using the V2L mode, really handy feature. Only bummer is that it's a vehicle stationary only feature. No running the coffee machine while driving.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
Year: 2015 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2015 Make...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
