LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,082
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
OK, I can narrow it down a bit more for you if needed;So, you conclude based on the Equinox EV that all EVs will behave the same. That must be true because all ICE behave the same in the cold. Not!
I haven't had much time at 10°F in my Tesla Model Y but I don't expect it to be nearly as bad as you describe. What I find on days which are roughly 32°F that the first 10 miles consume a lot of power (no matter shore preconditioning) then it tapers down to "normal".
The Equinox has an 85 Kwh battery so charged to 85% would be approximately 72.25 Kwh available.
Now to put a good kicker in it I would never plan a trip that would end with less then 20% battery in reserve, just like I would never go under a quarter tank in a gas/diesel vehicle. All it would take would be getting stuck, waiting for a stuck vehicle to get cleared of the road or an accident or detour to eat up the reserve. I am certainly not going to rely on someone else to deliver me fuel of any type to keep myself safe.
We were doing about 1.7 to 1.9 miles per kwh.
So a small 17 Kwh reserve from the 72.25 Kwh leaves 55.25 Kwh to travel with, or if I charged to 100% which would be 85 Kwh minus 17 kwh gives a max of 68 Kwh to travel with.
Or a range of 115.6 to 129.2 miles on clean dry roads.
The 1.7 to 1.9 miles per Kwh was cold and dry, no snow or slush to drag and require more hp to move through, during a bad storm with the wipers and defroster on high would most likely end up with an even shorter range.
So with those numbers I most certainly will not contemplate a trip of over 100 miles in the winter.
Now if you have a larger battery your numbers could be better, this is the advertised range.
The Chevrolet Equinox EV has an estimated range of up to 319 miles for front-wheel drive versions and around 280 miles for all-wheel drive version.
Ours is the awd version but looking at those numbers I see that we will be well under half the advertised range.
Yes, there are people that will push those numbers, they are also the ones crying and moaning about the lack of charging stations and how it's everyone else's fault that they ran out of "fuel" on the road.
