bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,886
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
During the warm months when the stove is not in use, dampness enters from the chimney and causes corrosion. I tried using Damp Rid and other moisture absorbing products, but there is just too much moisture for this to be effective. The flue has a damper but it doesn't seal completely and moisture gets past. For the last few years, I started taking out a section of flue pipe between the chimney and stove to keep moisture out. This works but as you can imagine, it's a messy job and leaves the stove unusable until the flue pipe is replaced. Not convenient if you want a quick fire on a chilly spring or fall day.
I'm not aware of any damper that seals the flue completely. What do others do to protect their stoves from internal corrosion when not in use?
