   / Share Pics of People Hauling or Towing Something Wrong #21,921
My wife’s car as the automatic high beams and we also turned it off.
One reason I say it’s people using automatic high beams is sometimes they turn off very quickly when you flash them or get closer.
It sucks to do it but I remember a drivers Ed instructor saying yes you’ll be blinded by their high beams but do you want them blinded too?
I return the "blinded" favor moments before we pass each other. They'd have to jerk the steering wheel to hit me then... not impossible, but less likely.
   / Share Pics of People Hauling or Towing Something Wrong #21,922
Don't know about other vehicles but my Tundra has a little wheel on the dash to adjust the headlight vertically from normal position downward to compensate for loads in the bed.
What year Tundra and what package level do you have? I have had a 2007 and a 2018 SR5 and do not remember seeing that dial. I know there is a dial for dash lamp intensity. Picture would be helpful of dial. Thanks. Jon
   / Share Pics of People Hauling or Towing Something Wrong #21,923
They're all adjustable, I'm guessing that you mean self adjusting?
If I remember correctly, my '23 Durango had automatically adjusted headlights.
A small thumb wheel on the dash or a lever on drivers side footwell with detents.
I was not aware the first time I rented in Germany and mentioned to my friend so many are flashing their headlights at me…
He said I had my adjustment set too high for city driving…
   / Share Pics of People Hauling or Towing Something Wrong #21,924
Eurospec Porsche 928 had driver-adjustable headlight height aim. Knob on floor to the left of the driver's seat.
Many in the USA figured out how to retrofit this feature. Remember the 928 headlights fold pointing up at the sky then lift into place when turned on. Even the USA model has to keep the light off until the fixture has deployed into place. So to adjust aim one just has to have a bit of control over the motor which deploys the lights.
   / Share Pics of People Hauling or Towing Something Wrong #21,925
If you’ve ever looked it up in a shop manual it shows how to adjust the headlights to spec. Usually aimed at a garage door or wall.
This is always how I've done mine. The biggest problem, in my little corner of the world (foothills of the Pocono subrange of the Appalachians), finding any stretch of flat ground longer than your car itself, is neigh-on impossible. You end up playing games with, "well, I'm on a hill, but at least the slope of the hill is constant".
   / Share Pics of People Hauling or Towing Something Wrong #21,926
I remember trying to buy an old/original Mini Cooper in Germany, to import back to the USA, and that had the 3-position roller switch on the left side of the dash for changing headlight angle, right next to the headlight switch. I remember asking either the seller or my German buddy what it was, and when they explained it, I was like... "you're kidding, right?" :ROFLMAO:
When I realized a driver plus three passengers and a few grocery bags would change the weight of the vehicle by a full 50%, it started making sense.
   / Share Pics of People Hauling or Towing Something Wrong #21,927
You should clock the projectors correctly before resealing the housing.
Then again, I had three sets of $1,600 headlights that had at least one projector each clocked wrong. That's when I decided to try a retrofit myself.
They were clocked correctly. The shutter for low beams wasn't straight. It looked like:
_______/---------
For both left & right. The lower bit on the left was to lower things for oncoming drivers. Higher on the right to catch signs & things on the side of the road. If you get the angled bit to line up perfectly at 100' the don't quite line up at 50' or 150'. Basic parallax error.
Also, when you (at least I) design & build things, others see something cool & does 99% of what it's supposed to. I see the 1% of design compromises or build mistakes. Pain of being a perfectionist you really don't get with an OEM system,
   / Share Pics of People Hauling or Towing Something Wrong #21,928
Maybe time to start a separate headlights thread. Drop a link to it here, if you do, so those interested can follow over.
   / Share Pics of People Hauling or Towing Something Wrong #21,929
Back to hauling something wrong... Somebody using a big truck to apparently haul a very small package a week or 2 ago. Looking at the photo, the truck looks lopsided, but I think that's just my camera work.
I sometimes have trouble with those vanity plates. What's this one supposed to read: "compensate"?
   / Share Pics of People Hauling or Towing Something Wrong #21,930
That's how I read it. Not sure why/what he is getting at but whatever...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
