   / Share Pics of People Hauling or Towing Something Wrong #21,861
Come to think of it, I spent a couple of days driving a Look-at-me! car earlier this year.
That was okay since there were no cops, and everybody knew it wasn't my car.
   / Share Pics of People Hauling or Towing Something Wrong #21,862
That was okay since there were no cops, and everybody knew it wasn't my car.View attachment 2088430
I had Plum Crazy and traded for Hell Raisin.
I tend to go for maroon/candy apple colors.
   / Share Pics of People Hauling or Towing Something Wrong #21,863
When my girlfriend wanted to buy a V6 Challenger I took for granted it should be a Granite one (she's the one who got me in tune with the dark gray metallics) so that's what I started looking for.
Meanwhile she found a local (150 miles away is local for us) one in Hell Raisin. Neither of us knew what one looked like in real life, but she just loved the name of the color.
As it turned out, it's a really nice (and cop friendly) color.
   / Share Pics of People Hauling or Towing Something Wrong #21,864
A lot of states have a law to turn on your lights when it’s raining. It just doesn’t sink in to some people. I originally wasn’t a fan of daytime running lights but have changed my mind since at least the headlights will be on for people that won’t turn their lights on.
my biggest beef with DRLs is the idiots who drive at night without turning real headlights on, because they just think their lights are dim when the DRLs are automagically on at night
of course, they're dark from behind
   / Share Pics of People Hauling or Towing Something Wrong #21,865
And as stated above just as important as headlights are the taillights. Traveling yesterday went through a couple of lake effect whiteouts on the interstate and you cant see the car in front of you because no taillights. Dusk/dawn is just as bad. Wife had her lights set and didn't realize she had no taillights until I followed her and commented her car disappeared in to the surroundings. I don't think most people realize that most colors given the right conditions blend into the surroundings making them virtually impossible to see. Whoever thought of DRL should have thought of adding taillights to it as well.
   / Share Pics of People Hauling or Towing Something Wrong #21,866
Speaking of steering trailers, I assume they still use hook and ladder fire trucks with a rear driver steering the back end.
They are still quite popular due to their extreme maneuverability. Before I retired Pierce came out with a straight (non-tiller) truck called an "All Steer" that steered the rear tandems.
   / Share Pics of People Hauling or Towing Something Wrong #21,867
The reason is because (at least on my car) the instrument panel lights are always on, also, my DRL's are almost as bright at low beams, so the only way you can tell from inside the car that the headlights are on is the little headlight symbol on the display. Another reason I don't like DRL's.
Whereas, if the lights are off, I can see it right away. I don't drive off without headlights often, but have done it a few times and that is why. Usually notice when I can't see the rear side marker in the mirror....
   / Share Pics of People Hauling or Towing Something Wrong #21,868
I’ve also noticed more and more people using their “automatic” high beams. On divided 4 lanes they often have them on for on coming traffic, not as bad as a two lane but still can be bright. They will also stay on as they are coming to pass you or you after passing them.
   / Share Pics of People Hauling or Towing Something Wrong #21,869
I’ve noticed a deterioration in what I’d call “high beam etiquette”, and had never thought it might be due to automatic high beams, but you might be onto something here. The reason I had never thought it might be the automatics is that every one I’ve ever owned has erred so far toward always turning them off, that I’ve had to disable the system on every car that has ever had it, as it often won’t let me turn them on when I want or need them. But maybe that varies by brand.
Over the last decade or so, I’ve noticed an increase in people leaving them on when following me. My current pickup has a bed light that can be switched on while driving, so that’s usually my first means of signaling them, but that usually doesn’t get the job done. Sometimes I’ll pull over, let them pass, and then follow their ass with my highbeams on for awhile… hoping it gets the message through loud and clear.
Even oncoming cars are leaving theirs on more and more. I’ll flash you once and give you about 2 seconds to respond. If not, I turn mine on and leave them on. My truck sits fairly high, and has HIDs, so the experience for nearly any oncoming driver is going to be far worse than what I’m experiencing.
These may be a-hole responses, and I’m probably naive in hoping that I can retrain others around me to think more about leaving their high beams on the next time, but it feels better than just lamely driving into oncoming highbeams with no response.
   / Share Pics of People Hauling or Towing Something Wrong #21,870
My wife’s car as the automatic high beams and we also turned it off.
One reason I say it’s people using automatic high beams is sometimes they turn off very quickly when you flash them or get closer.
It sucks to do it but I remember a drivers Ed instructor saying yes you’ll be blinded by their high beams but do you want them blinded too?
Ez-Go Electric Cart (A55853)
Ez-Go Electric...
378812 (A51573)
378812 (A51573)
SKID MOUNTED CONTAINMENT (A55745)
SKID MOUNTED...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
