   / Share Pics of People Hauling or Towing Something Wrong #21,841
Speaking of steering trailers, I assume they still use hook and ladder fire trucks with a rear driver steering the back end.
   / Share Pics of People Hauling or Towing Something Wrong #21,842
   / Share Pics of People Hauling or Towing Something Wrong #21,844
4WS has been done multiple times over the years including currently. The advantage is better control on the freeway and better maneuvering at low speeds. They work like others have said - steer same direction at speed and countersteer at low speed. It is complex and expensive - the downside.
   / Share Pics of People Hauling or Towing Something Wrong #21,845
A lot of states have a law to turn on your lights when it’s raining. It just doesn’t sink in to some people. I originally wasn’t a fan of daytime running lights but have changed my mind since at least the headlights will be on for people that won’t turn their lights on.
   / Share Pics of People Hauling or Towing Something Wrong #21,846
My '19 Jeep Cherokee has daytime running lights, but using the wipers automatically turn on the "regular" lights.
   / Share Pics of People Hauling or Towing Something Wrong #21,847
I don't understand why people buy a car marching the color of other drivers' dirty mirrors.
I surprised myself when buying a dark gray car after having had mostly white and easily visible ones.
Of course, having a light color wasn't nearly as important after leaving SoCal and having much lower temps. But the real reason was for it to be more stealth, flying under the radar at least figuratively speaking.
Many prefer the very eye catching colors that Challengers came in, which in my case would've likely resulted in several tickets by now. It does have DLRs so it can be seen, yet doesn't stand out, and I feel that it's partially my job to make others aware of that I'm there.
   / Share Pics of People Hauling or Towing Something Wrong #21,848
I recall the 2019 AAA report stating the most hit and accident prone vehicle color is B-L-A-C-K.
It's not IF your black vehicle will be in an accident, it's a matter of time when it does.
   / Share Pics of People Hauling or Towing Something Wrong #21,849
Ditto. I went Granite Crystal Metallic, or whatever they were calling the metallic dark gray. As aggressive as the styling is in those cars, you don’t need anything that calls even more attention.
   / Share Pics of People Hauling or Towing Something Wrong #21,850
Yep, Granite and debadged makes it blend in. This one was bought off the lot and I would've never thought to order stripes on it, but have really taken a liking to them. Kind of like ghost flames, they're there while far from obvious.
Probably should point out that this is not its natural habitat. Normally it doesn't get to see curbs, stop lights, etc., just twisty 2-laners.
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2022 Greenworks...
2013 Ram 3500 Flatbed Truck (A59814)
2013 Ram 3500...
Bad Boy Renegade Diesel Zero Turn Mower (A59814)
Bad Boy Renegade...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
