etpm
- Joined
- Jun 30, 2021
- Messages
- 2,395
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I have bought a few LED flashlights and they have all had their good and bad points. But the latest purchase has turned out to be most useful. It is a WUBEN E7. First the only drawback: the LEDs are on the side, not the end. However, this was necessary because it has two LEDs. Now the positives: it has 4 brightness settings, kinda bright, bright, very bright, and SUPER BRIGHT. Holy Cow bright! The first 3 settings are arrived at by just holding the power button down and it just rotates through the settings. For the brightest you press the power button twice rapidly. This makes it easy to pick the setting you want as there are not a lot of options. It remembers the setting so when you turn it off and then turn it back on there is no need to wait for the thing to rotate through the settings. Except for the brightest setting, you must always choose it, which I think is good because you don't want that bright of a light to come on accidentally. It has a magnet on one end and the power button on the other end and a belt clip. It doesn't have a lot of extra metal, it is basically a battery and a couple LEDs. The battery is replaceable. The thing is basically waterproof if it's in your pocket and gets soaked, I dunno how deep it can be submerged though. Anyway, it is small, powerful, and easy to use. $24.00 at Amazon. Link: Amazon.com
Eric
Eric
