Skid Steer undercarriage question for farm use
   / Skid Steer undercarriage question for farm use #11
This is the big reason I bought my Toolcat. It's in between a tractor and skid steer but with suspension. Front lift arm that can use SS attachments and a 3ph in the rear to use my tractor attachments. There are limitations like loader lift height but it sure rides better than either tractor or SS. It works great for my uses.
   / Skid Steer undercarriage question for farm use #12
Tracked SS machines have zero suspension. Wheeled SS machines have zero suspension.
They all ride like bricks.
You drive over a stick or rock, you feel it twice on a SS. On a CTL you feel it twice and the number of rollers in between the front and back idlers so usually there's 3 to 4 depending on the machine. That equals 5 to 6 times.
I'd steer clear of a used ASV unless it's very cheap or the hundreds of undercarriage parts all have been replaced within 4-500 hours. If you're buying new, check out the new Yanmar CTL.
BTW, Yanmar bought ASV about a year ago. They use a torsion type suspension on their machine that's reportedly giving an improved ride without the complex and expensive maintenance of the ASV.
On the other hand I believe it's agreed by most that ASV offers the best ride hands down. It's original design was for operation in snow in a utility vehicle. Think small snow cat.👍
   / Skid Steer undercarriage question for farm use #13
Look at small wheel loaders instead. I'd take my R410 over a tracked skid steer for everything other than grading. Much smoother in rough terrain, doesn't tear up the ground, better ground clearance, more precise side to side control, far better visibility. Add tire chains and it's nearly unstoppable.
I was going to bring the small articulated loaders up, But keep in mind, they don't do well on side slopes, AT ALL. Something like TCM, JD-344, and similar. Most? don't have nearly the hydro flow for stuff like brush cutters, milling machines, ect. They still don't ride good either
   / Skid Steer undercarriage question for farm use #14
Also, I think the latest series I'd JD Tracked SS have an air ride cab. So, no track suspension, but the cab as air springs between the cab and the suspension, if I remember right? Maybe that was the new series Cats? One of them does.
   / Skid Steer undercarriage question for farm use #15
The hydraulic flow thing is true. I'm not sure why they design them that way, but they won't run high flow attachments. Mine does great on side slopes. That's one of the reasons I like it so much. It'll go places where a skid steer or tractor wouldn't have a ghost of a chance and it'll be way smoother doing it.
   / Skid Steer undercarriage question for farm use #16
Do you have a different wheel/tire, or weight set up than factory? Cause most, if you are even on a 15% slope, running cross slope, and turn, either up or down the slopes, things get tippy Fast on ones I've been on (Cat and TMC). You would feel weird or in danger running a tracked skid on a 25% cross, maybe more, probably fully "safe" to greater than 30%
   / Skid Steer undercarriage question for farm use #17
A tracked machine with ride control or accumulators will ride better than wheeled
   / Skid Steer undercarriage question for farm use #18
No, it's original. They are not all created equal though. Some are more stable than others.
   / Skid Steer undercarriage question for farm use #19
The mini loaders do often have larger capacity buckets, at times/specific applications more agility, don't tear up stuff as much, and much greater mobility than a skid steer. I see them mostly with soft guys, landscapers, and land scape supply yards.
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
