yooperdave
- Joined
- Nov 28, 2001
- Messages
- 1,175
- Location
- Marinette, WI
- Tractor
- Tool Cat 5600, LS XJ2025H, Branson 4215HC
My rear tire lost its bead and now there is rim guard - beet juice everywhere.
I thought to possibly reseat the bead, I would add some air to the tire. When I went to add air, I could not unscrew the cap. After I turned the cap for awhile, the whole assembly pulled out. The assembly is a plastic insert that sticks into a rubber boot from the tire. I attached a picture.
I initially used a rubber tapered tip on the air compressor so I could try to reseat the bead. After adding some air and jiggling the tractor, I do not hear air excaping anymore for the time being.
How do you formally get air into the tire? The air chuck has nothing to grab onto. The LS dealer hired a new guy who knows nothing about this configuration. I am assuming this configuration was done to get the beet juice in the tire.
Can someone please explain the assembly and what keeps it from shooting out of the rubber boot? Also how to get air into the tire?
TIA
Yooper Dave
TIA
Yooper Dave
