Propane direct vent shop heater
/ Propane direct vent shop heater #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I have a small wall mounted direct vent propane heater, about 5-6 years old, that was working fine every winter until now. I usually have to clean the pilot thermocouple tip, but that's it. But now, the main burner flame is nice and blue close to the entry end, but mostly yellow at the far end. It shuts down after a heat cycle roughly, usually extinguishing the pilot. I relight it, and it may work okay for a day or so, but then shuts off on it own. I can't really access the main burner tube without a major teardown, and I don't have replacement gaskets... Gas pressure is fine- about 11 inches water column.
/ Propane direct vent shop heater #2
there may be some dust clogging up the burner venturi . Blow out with air. Propane usually burns more yellow than does NG though .
Just replace the thermocouple if you have no way to check millivolts in circuit, or out of circuit . You may also need to clean the pilot as you may have dust in the pilot assy. as well.
90in. Work Bench (A65640)
90in. Work Bench...
2020 INTERNATIONAL LT625 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 INTERNATIONAL...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2018 RoGator 1100C (A63689)
2018 RoGator 1100C...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
JOHN DEERE M15 - 15' BATWING ROTARY MOWER (A64277)
JOHN DEERE M15 -...
