TYM T574 DPF Error
/ TYM T574 DPF Error #1
ChetPT
Ford 2120, TYM T574HST Cab
This tractor has never triggered an automatic DPF cleaning. I have done a Manual DPF clean following the manual once. Now when the tractor starts I have a permanent error message stating the DPF is not working. I have removed the DPF filter and cleaned it thoroughly, and the tractor runs fine. Any idea of how to reset the DPF filter check engine light?
/ TYM T574 DPF Error #2
Here is a PDF for DPF info on The Branson Models, Its the same powertrain as the T574, so Im 99% sure it would be the same. Page 8 shows how to reset the light.
  • DPF Regen.pdf
/ TYM T574 DPF Error #3
That's a great PDF to have with great information there. Very complete. Even explains both types of regen that can occur. Thank you for sharing.
/ TYM T574 DPF Error #4
Can I ask what prompted you to do a manual DPF regen and not wait for the request?
/ TYM T574 DPF Error #5
Added to my manuals, thanks!!
/ TYM T574 DPF Error #6
Likely just need to reset the butterfly valve via the PDF posted.
Tractor de-rated and I needed to do manual regen to get my power level back to normal.
/ TYM T574 DPF Error #8
This engine can't de-rate. It's a mechanically injected engine, so it doesn't have a ECM to control it. It will throw lights in the dash as you've figured out.
I suppose it would run very bad and without much power if the DPF clogs so much it reaches that point.
De-rate may be the wrong term, but when mowing it lost all power and acted like it was choked, this all cleared up when I removed the DPF filter and cleaned it.
/ TYM T574 DPF Error #10
Yeah that makes sense.
That did the trick! Thank you very much!!!
/ TYM T574 DPF Error #12
Glad to hear it!
Its a very useful PDF, really TYM should include all that info in the owners manual....
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A67148)
2012 FORD E-350...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2017  MACK CXU PINNACLE T/A TRUCK TRACTOR (A67148)
2017 MACK CXU...
(UNUSED) JOHN DEERE RC10R ROTARY MOWER (A64278)
(UNUSED) JOHN...
More info coming soon. (A64557)
More info coming...
2020 Hino 195 Landscape Dump Truck (A64556)
2020 Hino 195...
