Ford 3000 Neutral Safety Switch
/ Ford 3000 Neutral Safety Switch #1
MickeyB
Ford 3000
I have a 1970 Ford 3000. When I put the hi lo gear lever in neutral the engine does not start. But if I wiggle it back and forth the starter kicks in intermittently. I have to move the lever into just the right position to engage the starter. Do you think it is a faulty switch or something else. I have seen you tube videos on how to change the switch and it seems fairly straight forward but I wanted to know if that is the problem before I change it.
Thanks,
Mickey
/ Ford 3000 Neutral Safety Switch #2
When our 3930 started getting intermittent, I jumped the contacts in the connector. After a few starts proved it, I replaced the switch. Easy replacement. Be extra cautious while it's jumpered.
Thanks Big, sorry if I sound like a novice but how do you jump the contacts in the connector? Is the connector the switch under the shift lever cover or the electrical connection above?
/ Ford 3000 Neutral Safety Switch #4
Pull the connector off. Then stick a u-shaped solid wire in to short across the contacts. Use a little tape to hold it and keep it from shorting to anything else.
This is for just long enough to diagnose and confirm the problem.
Cheers, will do.
/ Ford 3000 Neutral Safety Switch #6
Be extremely careful with a jumped neutral safety switch.
/ Ford 3000 Neutral Safety Switch #7
I had a similar problem on my NH 1920. Rather than deal with a reed switch, I replaced it with a pushbutton momentary switch mounted in the front panel. After many years of having to jiggle the shifter to get it to start, I now reflexively jiggle it before pushing that button. Works for me.
2011 Ford E-250 Cargo Van (A64556)
2011 Ford E-250...
2022 EZ-GO ELITE...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
HARDEE 16' T/A TILT BED TRAILER (A64278)
HARDEE 16' T/A...
