rubber hose fitting for hydraulic pump
   / rubber hose fitting for hydraulic pump #1
shc
Branson 2910i
low pressure hydraulic pump rubber return fitting for Branson
2910i
   / rubber hose fitting for hydraulic pump #3
It's the suction hose for the hydraulic pumps. You have to contact some dealers around and see if they can help you.
   / rubber hose fitting for hydraulic pump #4
Holy crap, tell me that's not a a specialized hose, good luck $$$$?
   / rubber hose fitting for hydraulic pump #5
Now that's Kore-engineering at it's best. I'm curious to see how you make out finding one of those. Won't be much in the after market world, and OEM replacements won't be around for long. If all else fails, I would be considering fabricating something from steel tubing and using three rubber connector hoses.
  • Good Post
Reactions: bgr
   / rubber hose fitting for hydraulic pump #7
That's the first thing came to my mind, "How can I make that out of tubing"
I'm going to the dealer tomorrow, hopefully they came across this before.
I found it at the dealership I bought the tractor at 20 years ago. In stock!
   / rubber hose fitting for hydraulic pump #10
Good on you...or the dealer actually LOL. Mind if I ask how much?
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
2018 Dodge 5500 Bucket Truck 4WD (A56438)
2018 Dodge 5500...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
Deere 50D (A60462)
Deere 50D (A60462)
