Yanmar Dash Parts (YM2002D)
/ Yanmar Dash Parts (YM2002D) #1
scooter133
Northern California
Yanmar YM2002D, John Deere D155
194151-55820 - Yanmar, Bulb, 12V3.4W (inscribed markings NSN 12V3.4W)
Also known as: HONDA OEM BULB 12V 3.4W) | 34902-259-003
With a BA9S base. The apparent LED equivalent is a 1157 LED Bulb.
Has anyone found a replacement LED version of this bulb that they like and works well for them?
194150-52160 - SWITCH ASSY, HORN/CHECK
194150-52170 -CAP, HORN/CHECK SWITCH
Thanks!
/ Yanmar Dash Parts (YM2002D) #2
Has anyone found a replacement LED version of this bulb that works well?
Thanks!
If you have the bulb, have you tried searching / cross checking the number stamped into the bulb?
All the best, Peter
/ Yanmar Dash Parts (YM2002D) #3
Are they the 53 bulbs found in the lamp gauge?
Then yes, you can go LED,
53, 182, 363, 1445​
LED Replacement Indicator Bulb 12VDC​
/ Yanmar Dash Parts (YM2002D) #4
Thanks!
You can reach out to Fredricks for the Yanmar OE part or get this online anywhere for the horn switch.
Or get something nicer like the newer Yanmar machines,
All the best, Peter
Thanks Peter, I’ve edited the question to be a bit more clear on my asking for the LED Bulb. I do have the markings and I’ve researched the bulb a bit, and the LED options look like crap. They don’t seem like they would fit in the rubber push-in’s on my Dash. I’m not looking for super bright Dome lights that are not needed, but are often the replacement LED version. I was hoping someone has used a bulb they like and could recommend that bulb, vs the junk I’m seeing out there.
Kind regards,
Scott<-
/ Yanmar Dash Parts (YM2002D) #7
Thats a Good Idea. I like that! They also make a Blank red ring for the Lamp Test button!
Thanks!
Is the YM2002D a new machine for you?
I edited the Question, but the bulbs say NSN 12V 3.4W,
The Honda bulb with part number 34902-259-003 is a 12-volt, 3.4-watt bulb featuring a BA9S base. The GE 53 bulb is a 14.4-volt, 1.73-watt bulb with the same BA9S base.
Thank you!
No, it’s not new. I think I got it in 2006? I’ve not been kind to it, so now I’m trying to go though some things and get her cleaned up.
/ Yanmar Dash Parts (YM2002D) #10
oh, you avatar only mentioned the Deere D155, so I assumed you just got the YM2002D
/ Yanmar Dash Parts (YM2002D) #11
Oh, now I see why you need a new horn button. I love the dash and controls your machine has.
Do you need any of the engine manuals?
I have the Parts, manual and service guides for the tractor. Thank you.
I do need a new Dash housing, Turn Signal Switch and Headlight Switch.
I have not dove into those 2 switches yet. I am open to non OEM types.
Though I looked the Hole for the Horn button is about 7-8mm. That Horn button on Amazon was 16MM. I’d have to carve out the holes for the 16mm version. I’ve seen a 12MM button. Will have to get some coming to see how they feel.
/ Yanmar Dash Parts (YM2002D) #13
To save time, I already dove into the headlamp switch. In extreme detail.
New Leader MultiApplier Spreader Box (NEW) (A63109)
New Leader...
Atspower Mini Excavator (A60352)
Atspower Mini...
2015 Chevrolet Silverado 3500 4x4 Service/Welding Truck, VIN # 1GC2KYEG3FZ124159 (A61165)
2015 Chevrolet...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61567)
2019 Toro...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
UNUSED ATS CMR1280 ELEC.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
