3-Point Hitch PTO Generator arrived today
   / PTO Generator arrived today #141
I very seldom adjust my throttle once I'm set, I'm running a 25Kw and it just powers along as the load varys I may see a 1 Hz change and a couple of volts but nothing to go out and adjust for.
1 Hz is a lot to sensitive electronics.
   / PTO Generator arrived today #143
If I do my math right, 1 Hz, means you've lost around 50 rpm. Seems like a lot for a governed engine.
   / PTO Generator arrived today #144
I guess I'll have to watch the freq close the next time I'm on the generator. If I'm using the Branson she's on the economy mode and turning about 1700 rpm with a plus/minus 10rpm as I recall. When the IH574 is on it she's right around 1900 rpm and fairly steady. I normally use a killawatt meter in the house to monitor Voltage and Hz and neither vary enough for me to worry about. I've never lost any electronic or electrical device while on generator power. I have seen lost time (4-5 min) on a wall clock after a few days of use.
   / PTO Generator arrived today #145
My Massey easily looses 200 rpm’s from no load to full load. I wouldn’t ever use it for a PTO generator for that, and the bigger reason being, I need it for other chores, like snow blowing, bucket work, etc..
   / PTO Generator arrived today #146
Just a reason for more tractors
   / PTO Generator arrived today #149
I NEED to get a pto gen. so my wife doesn't make me get rid of one of the tractors......;-)
   / PTO Generator arrived today #150
The thread starter here has a 25 or so HP subcompact tractor. I also have one and I'm not convinced there is a governor. The throttle lever controls the fuel feed in the injector pump but I don't see any sort of feedback device. I think any significant load increase is going to drop the RPM's until the throttle setting is manually increased. I could be wrong. One of my concerns is that running unattended for a few hours, the throttle lever, held in place by friction, could drift.
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
