Ym276d not starting
/ Ym276d not starting #1
kempryan28
Member
Yanmar YM 276D
Howdy gents,
I’ve been having a problem with my ym276d starting up. When I turn the key it is very inconsistent on whether or not it fires the starter. If I hook it up to my battery charger and set it to “jump” mode then it will typically start just fine.
I checked the battery first by taking it in to have it tested at an auto shop. They said it was all good to go. So not that.
Next I thought maybe the starter, so I ordered a new starter and put it on the tractor with the same problem occurring. So I sent it back and put the old one back on (after I took it after and inspected brushes and cleaned it out as well).
I have read many different threads on this and have found that putting a volt meter on it and testing if it’s getting its required 9v to the starter to make it turn. With ignition off it is getting 12.7v when my wife would turn the key to try and start it the volts would drop to 4v. I did notice that if she held the key to start the volts would climb and eventually fire the starter (it did this once or twice).
I replaced the ignition switch last summer, that didn’t seem to matter. Same problems occurring.
I bypassed the clutch safety switch to rule that out and I’m still having the issue. I see on my electric schematic that it also has a pro safety switch I have not yet located that to attempt to bypass it as well. However I do ensure the pto is in neutral when attempting to start.
I’m lost on where to look next. I’m certainly not an electrical genius. Ie I have a volt meter and get lucky every once in a while and use it correctly but beyond that I’m lost.
Any ideas on where to go from here?
As always any help is appreciated.
Thanks,
Ryan
Electric system schematic for reference
Also of note I forgot to take pictures of it but the pin connectors out of the voltage regulator had appeared to get very hot at times and nearly fused one of the wires perhaps causing a short. I replaced the regulator with one I had laying around add wire nutted the wires together until I can replace the pin connector. This didn’t fix anything either but it did appear to get hot out of the regulator at some point enough to damage that pin connector.
Check all your battery connections at both ends of each battery cable. Take them off and wire brush them and reinstall.
Thanks I did try this although I will admit I didn’t get them as clean as I could (my wife brush wouldn’t fit in all the nooks of my cable ends) but I got em about 90% there.
I’ll bring the right brushes up next time I’m at the property and get em good and clean.
Thanks
/ Ym276d not starting #5
Thanks
@kempryan28 When you jumped the battery with your charger, where did you connect the charger cables? Can you wiggle the battery post at all? It almost sounds as if you have a loose connection in the battery.
Don't forget to check that the wires going into the battery connectors are ok, too, i.e. they haven't corroded inside the cable or the clamp, or mostly broken due to vibration and arcing. To me, the 4V voltage says that you have a bad connection within the wire, or within the battery itself or a bad wire, or a bad ground connection. It seems as if when you are jumping the battery, you are either knocking a wire/clamp into a good contact, or bypassing the battery.
BTW, where are located?
All the best,
Peter
All the best,
Peter
Howdy Peter,
I connect the cables to the positive and negative terminal on the battery over the top of the cable clamps.
I don’t believe the posts wiggle. If memory serves me correctly they are solid when I hook up to them but I will check next time I’m at the tractor.
I can check out the cables when I take them off at both ends and clean them with the brush per racer4’s suggestion as well.
I’m suspicious as well of just bypassing the battery when I jump it as I clamp onto the top of the cable clamps. I’m curious if when I took the battery to a shop if they testing it under load as well. Is that standard testing for a parts store test?
Thanks
/ Ym276d not starting #7
Howdy Peter,
Thanks
Given that clamping the charger on the battery posts works, I think that taking a battery to a parts store to be tested on a load tester is the thing to do at this point. Good luck!
All the best,
Peter
/ Ym276d not starting #8
All the best,
Peter
Sounds like the battery needs replacing. The auto store guy doesn't know what he's doing.
It takes time and a load tester to check a battery for the ability to provide a lot of current needed for starting. There are testing shortcuts. but they still take a full work day or more. Optima battery company requires a 12 hour load test for warranty claims. I think that's excessive, but on the right track.
Try this: take the cables off the battery and charge it at some moderate rate for overnight.
Then disconnect the charger, let the battery just sit there disconnected for an hour and then measure the battery voltage. It should be in the 12.7 to 13 volt range.
Now just leave it there still disconnected and let it sit for at least overnight or better yet for a day. Then measure the voltage again. It will drop some...but not much. Maybe 0.2 volts is typical for an older battery. New ones drop little if any. .... So if it was reading 12.7 after charging and sitting that hour, it should still be above 12.5 after sitting a day.
If it dropped down to 12.4 or below after 12 to 24 hours, the battery is not reliable for starting. It's still good as a 12 volt source for lights and such, but not for starting
luck,
rScotty
BTW, congrats on the starter brush rebuild. Nice to see someone doing it, Be sure to lightly sand the commutator and remove any carbon between the commutations.
And take the solenoid apart and clean those big contacts inside. That is often the problem with starting.
In order, troubleshooting goes: CABLES, BATTERY, SOLENOID, IGNITION. SWITCH, STARTER MOTOR.
/ Ym276d not starting #9
Thanks
Try a jumper wire from the + battery terminal to the solenoid terminal on the starter. If the starter spins reliably, then the solenoid is OK, if not replace.
Also, if the tractor lives in the weather or in an open shed then it's possible that the main battery/starter cables have corroded inside their terminals. Try connecting the battery to the starter with known good jumper cables & see if there's a difference. I have a Cushman Truckster (Kubota engine) that lives in an open shed that had this problem which drove me nuts for ages!
/ Ym276d not starting #10
If the Battery connections on the cables have been replaced I've seen lose/Dirty connections on them countless of times. That shop can test or should test the CCA. or Amps. that you can't with just a V-meter. Amps=Volts. Which I use the highest CCA battery that would fit in the tray. 850 from Walmart. I used a 550 for Yrs. and was glad to finally see it go in the trash!! Charged it up before use all the time.
/ Ym276d not starting #11
On your YM276 the battery ground cable does not connect directly to the frame of the tractor.
When you disconnect it to clean the connections you will see that the ground cable connects to the pan
(# 37) the battery sits in.
The pan is bolted to the frame and this is what actually creates the grounding.
You should remove one of those bolts (#53) and sand the rust and paint off to be sure you are getting a good ground connection.
Thank you everyone! Sounds like I need to be more highly suspicious of that battery.
I think I’ll plan on going up there with a fresh 850cca battery next time, also clean cable connections, check my ground, and test the starter directly with some jumpers to rule out the cables themselves being bad on the inside.
I’ll follow up and let you all know what came of it or if nothing worked we need to keep digging.
Thanks again! Ryan
Thanks for this. I’ll look at those spots as well.
Thanks… I did get a new 850cca ever start max group 65 from Walmart for it a few years back it seemed to work nice but maybe hasn’t lasted as long as I wanted it to.
Has anyone been able to fit a bigger battery in it or found something with more CCA? Open to recommendations on what to buy and head up with next time I go.
luck,
rScotty
Thanks for this. I’ll head up with a new battery and see what she does.
And yeah the starter wasn’t to bad at all. I guess my philosophy on any parts has always been it’s not broke until I’ve taken it apart, inspected it, cleaned it, and put it back together again… I win some I and lose some but it’s always a good adventure.
All the best,
Peter
Also forgot to answer your last question. I’m in Eagle, Idaho. The tractor lives at our cabin in the small mountain town of Cascade Idaho an hour or so north of me.
/ Ym276d not starting #17
Group 24F is taller 750CCA and peak 975CCA. You would need to ensure the cables reach. This is what I have in my YM2610 right now.
Ideally, you need to bring the battery back for any warranty issues. The group-65 is very pricey to replace. If outside of warranty, you would need a battery recharger capable of reconditioning like this one,
And it's on sale this entire weekend!
https://www.harborfreight.com/2815-...ocessor-controlled-battery-charger-56796.html
I've restores countless vehicle batteries with this device and saved several Lithium power tool battery packs with it too. When the battery packs don't take a charge at all, I toss this on for an hour at 2A. Then transfer over to the normal battery pack charger and it works.
/ Ym276d not starting #18
Thanks! I think that is gorgeous country. A location often helps folks here better answer questions. You can put it in your profile for the future, too.
I've been known to upgrade battery cables to heavier duty ones with better (heavier gauge, larger) lugs, with star washers on the tractor ground for better contact. Starters draw enormous amounts of current, and every little thing that you do to reduce the resistance in the wiring helps. For me, if I ever have vehicle starting issues that aren't a dead battery, the positive cable and ground cable both get upgraded as step one.
Despite Japan's snowy north, I do sometimes wonder if Yanmar generally assumed that its tractors would be used in warmer weather.
All the best,
Peter
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
