T574H Hydraulic Top Link
   / T574H Hydraulic Top Link #1
halfBaked2024
No cattle
I measured out my manual top link and there don’t seem to be any hydraulic offerings with similar dimensions. Is there a brand/model you T574 owners found to work?
Max: 28-3/8”
Min: 18-3/8”
Bushing bottom: 55mm (2.163”) wide, 19mm (0.75”) pin
Bushing top: 42mm (1.653”) wide, 19mm (0.75”) pin
I know 10” is a lot of stroke to ask for, but at least I want the max opening length, right?
   / T574H Hydraulic Top Link #3
Max: 28-3/8”
Min: 18-3/8”
I don't think that you are going to find a hydraulic unit with those dimensions.
I have found that if you look at the following link, get the asked for dimension and find a hydraulic unit that provides that asked for dimension for the mid stroke (24"?) that is about the best that you are going to get.
I'm fairly sure a 19 1/4"- 27 1//4" would be a good fit, but that is only based on what others have told me. Is this a cat 1-2 top link or straight cat 1 unit?
I am still learning categories, tbh. I know the 3P rating is 3,000# - 4,000# and the tractor is 55HP. Does that help?
   / T574H Hydraulic Top Link #6
For top links.
Std cat 1 pin size is 3/4".
Std cat 1 ball swivel is 1 3/4" wide.
Std cat 2 pin is 1".
Std cat 2 ball swivel is 2" wide.
Narrow cat 2 (1 3/4" wide) ball swivels are typically used at the implement end (rod end) so that the cat 2 ball swivel can be used for cat 1 implements with a reducer bushing to 3/4" for cat 1-2 3pt hitches.
I recommend a 2 1/2" dia cylinder with a 1 1/2" dia rod for your application.
A lot, (but not all makes) 50-60-HP tractors in the frame size that you have are cat 1-2 3pt hitches. 3/4" pin at the tractor end and a narrow cat 2 ball swivel at the rod (implement) end.
Look at the the previous link, get that asked for dimension and go from there. ;)
   / T574H Hydraulic Top Link #7
I've got the same tractor. It's Cat 1.
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 MACK GRANITE CV713 DUMP TRUCK (A60430)
2005 MACK GRANITE...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
