T574H Hydraulic Top Link
   / T574H Hydraulic Top Link #1
halfBaked2024
No cattle
I measured out my manual top link and there don’t seem to be any hydraulic offerings with similar dimensions. Is there a brand/model you T574 owners found to work?
Max: 28-3/8”
Min: 18-3/8”
Bushing bottom: 55mm (2.163”) wide, 19mm (0.75”) pin
Bushing top: 42mm (1.653”) wide, 19mm (0.75”) pin
I know 10” is a lot of stroke to ask for, but at least I want the max opening length, right?
   / T574H Hydraulic Top Link #3
Max: 28-3/8”
Min: 18-3/8”
I don't think that you are going to find a hydraulic unit with those dimensions.
I have found that if you look at the following link, get the asked for dimension and find a hydraulic unit that provides that asked for dimension for the mid stroke (24"?) that is about the best that you are going to get.
I'm fairly sure a 19 1/4"- 27 1//4" would be a good fit, but that is only based on what others have told me. Is this a cat 1-2 top link or straight cat 1 unit?
I am still learning categories, tbh. I know the 3P rating is 3,000# - 4,000# and the tractor is 55HP. Does that help?
   / T574H Hydraulic Top Link #6
For top links.
Std cat 1 pin size is 3/4".
Std cat 1 ball swivel is 1 3/4" wide.
Std cat 2 pin is 1".
Std cat 2 ball swivel is 2" wide.
Narrow cat 2 (1 3/4" wide) ball swivels are typically used at the implement end (rod end) so that the cat 2 ball swivel can be used for cat 1 implements with a reducer bushing to 3/4" for cat 1-2 3pt hitches.
I recommend a 2 1/2" dia cylinder with a 1 1/2" dia rod for your application.
A lot, (but not all makes) 50-60-HP tractors in the frame size that you have are cat 1-2 3pt hitches. 3/4" pin at the tractor end and a narrow cat 2 ball swivel at the rod (implement) end.
Look at the the previous link, get that asked for dimension and go from there. ;)
   / T574H Hydraulic Top Link #7
I've got the same tractor. It's Cat 1.
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2019 CATERPILLAR 246D3 SKID STEER (A60429)
2019 CATERPILLAR...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
skeleton / rock bucket (A56857)
skeleton / rock...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
