scootr
Super Member
- Joined
- Aug 9, 2022
- Messages
- 8,607
- Location
- Temecula California
- Tractor
- Kubota MX5200 HST, 773 Bobcat, Cat forklift
12x17 I would quarter it.
I assume you mean four 6x8.5, but part of me thinks that it would be easier to do long narrow strips, 3x17. Screeding is much easier with a narrow strip.12x17 I would quarter it.
Cold joints, no expansion. Definitely use reinforcement in the form of rear or wire. Make sure you finish the joint edge nice. When you go to pour up against it lay down a sheet of 10mm plastic so you pour over the plastic and it covers yesterdays pour to keep things nice. Then just cut the plastic off when you are done.I assume you mean four 6x8.5, but part of me thinks that it would be easier to do long narrow strips, 3x17. Screeding is much easier with a narrow strip.
Question two: should I do cold joints, tie them with rebar, have expansion joints?
Hmm, I think I would avoid having 3 joints in the doorway, so I guess given the choice, I would go 12x5, 12x7, 12x5. Knowing the middle section will be the easiest, because you are working off two fixed points, and working the middle. I just think it would look like a turd if you have 3 narrow pours, and the exposed joints all at the 12 ft door.So the slab is 12x17, the door is in the 12' end. So would you recommend three pours of 4x17 or three pours of 12x 5'+?
If it doesn't matter, it seems to me the 4x17 would be easier, I can roll the mixer between them the whole way. Do the two sides and let them harden and then roll the mixer in on one of the sides to do the middle. It also would mean I never have to drive over the joints.
I would do 3, 5+ x 12. I did cold joints (construction joints) tied with rebar (not expansion joints). Has held up beautifully.I assume you mean four 6x8.5, but part of me thinks that it would be easier to do long narrow strips, 3x17. Screeding is much easier with a narrow strip.
Home Depot does a discount on single full pallets, but Lowes, last I bought, you had to buy 2 full pallets to get the bulk discount. Never asked about delivery fees, but with a Moffet/Piggy Back forklift, they can deliver the pallets to right where you need.Thanks. A thickness of 4" is 2.5 CY, 5" is 3.1, 6" is 3.8. I think I'd rather use rebar than mix and pour another 1.3 CY.
A 12x7 section 4" thick is 1.04 CY, so almost exactly a yard, a good day's work.
My local rental house wants $50/day for a small mixer and $115/day for the big (9 cu ft) one. Since I'd have to rent for three days it seems worth buying a small mixer from Home Depot, Harbor Freight or Amazon.
The Quikcrete Concrete Calculator says 152 60lb bags for 2.5 CY.
Mine, I did wire continues through the whole floor, and only used a edger at the edges, so the WWF held the separate slabs together. Your bulk head form, you can rip down a 2x4, and only have it say, 2.5" "tall" and run the wire free through it to the next section. If appearances matter, you can always use a polybutylene caulk on the joint later, after maybe 28 days.I would do 3, 5+ x 12. I did cold joints (construction joints) tied with rebar (not expansion joints). Has held up beautifully.
If you are under 40, a BFI under 20%, a strong back and a healthy set of lungs, you stand a good chance of success doing by your self.
The higher the numbers, the more help and work time you need.
There is one local guy that will deliver in this set up, and about 1h away there is a rental company you can do it yourself. Only thing difference, it's redimix, and you don't add water. The catch with the rental place, the 1 cy of concrete includes 1 hour of rental; but the issue, it's 1 h away, you need to pour, clean up, and then... what take it back and hope 2 hours it hasn't gone too far to finish. I would want to at very least float and edge. After 2 hours, on a cool day, sure you can still work a cream back up, and broom, but on a hot day...About a decade ago I needed concrete for an area that would be hard to get a full size truck mixer into. I found a a place that rented “you tow it” concrete. Basically a trailer mounted mixer that held 2 cubic yards of concrete. They load the dry mix and you add the water at home and turn on the mixer. Those units can be truck towed and get into as tight a spot as you can back it into. Break up your slab into 2 yard sections.
But, also in most places there are small concrete contractors who will do small jobs. Maybe search a bit more.
Sounds like you need a helper to drive the trailer back after your pour while you work on finishing the concrete.There is one local guy that will deliver in this set up, and about 1h away there is a rental company you can do it yourself. Only thing difference, it's redimix, and you don't add water. The catch with the rental place, the 1 cy of concrete includes 1 hour of rental; but the issue, it's 1 h away, you need to pour, clean up, and then... what take it back and hope 2 hours it hasn't gone too far to finish. I would want to at very least float and edge. After 2 hours, on a cool day, sure you can still work a cream back up, and broom, but on a hot day...
How much "r etard" can you put in and have it still bond like it needs to?
I see they now have machines that will build walls by putting down layers like squeezing toothpaste from a tube.
Can one pour say 2 foot wide sections next to each other and have them bond?
(note-I tried to write the word I had read used for slowing down the curing, but it all turned into astericks)
Are those pads in the picture 5'x12'?I would do 3, 5+ x 12. I did cold joints (construction joints) tied with rebar (not expansion joints). Has held up beautifully.
Body Fat Indexok I'll bite
what's BFI?
retarderHow much "r etard" can you put in and have it still bond like it needs to?
