Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix?
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #21
Same thing happened on my Woods backhoe a couple weeks ago. I just ordered a new one from Discount Hydraulic Hose, it was 127" with 3/8 JIC fittings. It's a better, higher pressure hose about $64 with shipping.
My opinion is it's much better than trying a patch.
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #22
I have a buddy who is an aircraft tech. He told me they repair leaks in aircraft steel hydraulic lines by cleaning up where a pinhole is back a couple inches from the pinhole, then wrap with bare mechanics wire, then silver solder it. I've looked for videos on this procedure but have yet to find any info on it.
I have a line on my Bobcat that has rubbed enough it also has a pinhole in it. I'm about a half notion to try this type of repair. If it doesn't work, I have a local hydraulic shop that does make new metal lines but have no idea of cost. And the guy that makes them only does it a couple days a week, so I'd have to call ahead and see when he is available to make on.
I already took it off once and took it to them, and at that time he was on vacation. Didn't have the wire or solder to attempt it at the time so put it back on. Not the easiest place to get to for an old guy, but things have slowed since it's coming wintertime, and have a little extra time to work in the shop.
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #23
There is a "Hosepatch", but its more for emergency use until you can go get a new hose, I remember coming across this one a few months ago and filed it away...
Not cheap but its reusable. Someone may know of a cheaper one time use product.
NOTE: there are different sizes - this link takes you right to the 1/4" size....
That kit requires the hose be completely cut for use, it's not a "patch".
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #25
Go an hydraulic shop or any other place that makes hoses with the old hose, get a new one made and don't worry about it.
Cost me $12 or $13 and 10 minutes to get a new hose made just the other day.
I wish we could get lines for those prices, a couple of 3/4" 4 footers are over $70 each from the local shops.
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #26
To be fair, it was a short 3/8" 2 wire hose, 50cm long or so, with straight male DKOL-12L fittings.
When I built my loader, I bought all the hoses and fittings from a place in the UK. 12 3/8" hoses, all 2 wire, various fittings and quick disconnects, was about $200 or so.
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #27
I've got an inventory built up of 3/8 and 1/2's but no 3/4's, 20-30 different hoses on had and several hundred dollars in fittings but it seems like many times I need something else. I'll often buy more then needed just to have one.
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #28
I can see this working very well. You wouldn't need to wrap wire two inches on either side of the leak, just clean it that far. If you attempt this I suggest wrapping wire perhaps only a 1/4 inch or so from the leak. Maybe 3/8. Flux the tube and wire very well and wrap tightly. Then do the silver solder. Make sure ALL the wire, all the way around tube gets soldered.
Eric
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #29
My experience, a GOOD hose supplier won't crimp new fittings on an old hose. If that's your plan, it's your plan. Not something I would nor recommend. As for the reusable fittings, unless the removing the bad hose is a three day job, using them as a "temporary" fix is a waste time and money. Have a new hose made and be done with it.
   / Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #30
Eric
Guess I was envisioning what I need to repair with what he said. Line on mine has rubbed an area about 3/4" long, so will buff a couple inches all together, not necessarily wrap wire for the 2". Wrapping/soldering seems easy enough to do, just not looking forward to pulling that line out.
2023 BigTex 10SR-12XL T/A Dump Trailer (A56858)
2023 BigTex...
UNUSED 1RMC HIGH END MASSAGE CHAIR (A58376)
UNUSED 1RMC HIGH...
Indy Power Wrench (A57454)
Indy Power Wrench...
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
