How far is too far for driving tractor on the road?
   / How far is too far for driving tractor on the road?
17.8 mph seems about right at WOT. I run slightly less than that so I'd guess about 15 mph. The route I take to the property crosses #1 on 96 highway a two lane there. Lots of traffic but fairly well traffic lighted up. A few small towns along the way but the bulk of it is pretty rural. Mine isn't the HST but a geared model.
As for the JD F1445 its a front commercial grade mower. No 3pt on it. Its a beast when mowing. I can mow our 19.+ acre farm in about 4.5 hrs when I'm motivated and hadn't let it get too tall. Much of that is dodging fruit trees/bushes, vineyards.
   / How far is too far for driving tractor on the road? #33
I took this picture of a rig from Germany in my village in southern Portugal. That's a fairly long way.
And he's not unique; I met another German who pulled a gypsy wagon at 4mph all the way through Europe too, on an antique "Hanomag" tractor without a cabin.
He was totally cooked when I met him.
   / How far is too far for driving tractor on the road? #34
I haven't read it all, but there really isn't a Too Far, but you put a lot of wear on tires on asphalt. So, if I had too, 1 hour, or even 2 hours would be OK, but I wouldnt do it often. We aren't talking about a large machine, a Uhaul car trailer would move it behind a medium SUV
   / How far is too far for driving tractor on the road? #35
Where I live folks generally give wide berth to tractors, joggers, walkers, bicycles, etc. It's apparently just a thing here. At the same time some folks don't. But what does the state say about driving that far? I called the Washington State Patrol about driving my tractor on the road. I was told that if I was driving from one gate to another that goes to my property, and that if the property was contiguous along the road, that I would be OK. But driving from one property that I own to another that I own but that are not connected, was illegal. I remarked that I see tractors driving on the county roads on a regular basis that I know are not going from one end of their property to another. The WSP guy said that they are breaking the law and are subject to traffic fines. But I wonder how often this really happens, a tractor getting a ticket. I suppose if a WSP officer saw a tractor making regular long trips they might ask questions. Different states have different rules so it might be good to check.
Eric
   / How far is too far for driving tractor on the road? #36
As a data point
My cousin farms in north East South Dakota. He leases quite a bit of land to make the operation work. Some of those pieces are 35 miles apart. At planting, He runs the tracked tractor between fields as needed. But only when the roads are wet. Too much heat on the tracks and bogies otherwise.
   / How far is too far for driving tractor on the road? #37
I wonder how far the ag protesters in England and France are driving?
   / How far is too far for driving tractor on the road? #39
I roaded my tractor recently for barely a mile in each direction and let me tell you driving ~12mph was very wobbly - had to pay close attention to keep it going straight. Think a 30 year old car with worn out recirculating ball steering and worn out tie rod bushings, to the max.
I'd imagine this has something to do with tires, and higher tire pressure would probably help with roading, but I also suspect that the entire front steering setup isn't designed to be precise. Bigger tractors are likely better set up for roading because people actually do it. Who knows, maybe mine's steering is f'd up. Seems to work fine for everything I do on the land.
I definitely wouldn't want to drive more than a couple miles, and if I had 43 miles each way to go multiple times, that would be an immediate escalation in "I need a trailer" status.
   / How far is too far for driving tractor on the road? #40
Yes, road lighting and turn signals etc. 25 MPH transport speed to stay within SMV territory too.
2019 Isuzu NRR 1,200 Gallon Fuel Transport Truck (A56858)
2019 Isuzu NRR...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2018 HINO SA (A58214)
Case 930 Tractor (A59814)
Case 930 Tractor...
