npalen
Elite Member
I'm using a 4-pin flat to 7 pin adapter but not sure where to pick up a switched 12VDC at the rear end of the Dakota pickup for charging. Could tee into the tail light circuit but the lights are manual only so would have to remember to turn the lights on.yea it will be fine, just start the truck before connecting. it won't sit at 50amp long, the battery is pretty small, mine is just a 4 way pin, not sure why you wouldn't enable charging if your running a 7 pin, there is no charger on these trailers.
Are you talking about the battery for the electric brakes emergency actuation when you say its "pretty small". I will not have electric brakes on the new trailer.
