A timber frame cabin memoir
   / A timber frame cabin memoir #111
That's the way mine is. They have you cheat the walls past the timber 1.5" so timbers are exposed even after drywall or wood finish. Yet the 2x6 will be flush with the outside of foundation. Then the sheathing can overlap flush with the foundation before the wood siding goes on.
I have to install 2x6 nailers between studs every 2' on center. This is alos to provide a good nailing for the siding besides just the sheathing.
I could be wrong, but I think that @JJT put the entire 2x6 outside the timber. That way it is a sheath holding insulation, wiring and pipes. Much easier than trying to fit the walls inside the timber frame. I did the inside timber frame once. I will not ever do that again, as each stick needs pretty careful measurement.
All the best,
Peter
   / A timber frame cabin memoir #112
A trick I was told for tipping up floor built walls when ceiling and floor in place and no room to tip. Nail additional top plate in place on the ceiling. Build wall to 1 1/2" shorter height. Tip up, slide under extra top plate, level and secure top and bottom. Jon
The building in place has made it easier other than the toenailing. I do measure each individual stud and fit it tight. Cut again if too tight etc. A little time consuming but has made me happy. It has also made the building windows in place a little easier. I neglected to take a picture after I had the deck door framed and had started on the last window. I've been looking online as to how to frame in triangle/trapezoid windows. I'll holler at the timber frame folks but was curious.The red box drawn in is me depicting a beam in the wall that the upper section will be framed off of. There's a very strong chance I will hire some folks for a couple days to frame this whole upper part in but I want to pay close attention. I'll make sure they get angles correctly as that is not a common window style. One online suggestion I read was frame it like a box window then fill in around it. Makes sens as your loads are getting transferred in a more proper fashion.
   / A timber frame cabin memoir #114
For toenailing, cut a spacer block to go between new stud and the prior one. Then drive your toenails on side of stud opposite of spacer block. Remove spacer block, and toenail that side of stud. Do bottom of stud first, then top of stud. Jon
   / A timber frame cabin memoir #115
@caver I have lived in a few homes with similar trapezoidal windows. While all of those were framed in with wood trim, I would suggest finding a nearby window manufacturer to make them for you in a double or triple pane. You will get a one piece window that will be more rigid and easier to frame and seal into the house. The wood built in windows are, in my experience prone to leaking, especially if not caulked in place, and a lack of a continuous seal leads to leaks and rot at a really inaccessible point on the house. Plus, once a little moisture gets into the space between the windows, it hangs around and the semi-frosted/fogged window look isn't a great one in my book.
I would a boom lift to put them in. They will be heavy and awkward.
All the best,
Peter
I will order windows from Andersen via a lumber yard. I got a quote sometime back.
   / A timber frame cabin memoir #117
You really shouldn't need headers on the gable wall as it is non load bearing, in almost all cases. Especially with a timber frame. The timbers should be carrying the loads, not the infill framing... Get the specs from Andersen on framing them before you get too far, as they may have some quirks due to the shape.
   / A timber frame cabin memoir #118
I agree with this.
For the top angle, just figure out what the framing width needs to be for the windows you are using. Some windows are exactly what they say they are, others are framed that size and actually half an inch smaller. It really depends on what you buy to know what your measurements are.
I have the RO measurements from the lumber yard quote.
As far as the headers, they are required on the lower section per the timber frame folks. The only difference is if there is a beam like in the picture it only gets one top plate. On the back part it will get two top plates those tie beams are not there due to the loft floor. Any opening above 36" actually gets a 2x10 header. Smaller gets just a 2x6 header. I'm awaiting a response from Legacy on the framing but contacting Andersen might also help.
   / A timber frame cabin memoir #120
I put headers in all the door and window openings of my timber frame house. Totally unneeded, but the code enforcement officer had no timber frame experience.
100% of the walls in my timber frame house are non load bearing, the timber frame carries all of the load.
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
2018 RAM 2500 (A58214)
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
2010 SHOP MADE WINDMILL TRAILER (A58214)
2010 SHOP MADE...
Bucket (A55973)
Bucket (A55973)
