Turn Signal Flasher Relay
/ Turn Signal Flasher Relay #1
Paystar
Elite Member
Ontario, Canada
Kubota B2620
So the turn signal flasher relay just suddenly failed in my RTV-X1100C. When I turn a signal or 4-ways on, all four exterior and the dash indicators stay on solid.
Kubota wants $200 for this relay here in northern Ontario, so I bought a whole new complete signal kit for $300 instead as dumb as that sounds.
Anyway, my question is, is there anything I should check before I try new one, or do you think it just failed? Would something else cause it to fail prematurely? I don't see any damaged wires. Today I'll pull all the bulbs and check them.
It's an 8 pin relay. Any way to test it with a multimeter? I did find a you tube video on testing an 8 pin but it's in a foreign language and I can't understand a thing he's saying, LOL
/ Turn Signal Flasher Relay #2
Cant help on the relay but I do watch a bunch of the non english you tube vids.
Have you gone into settings on the vid to see if it has auto translate captions.
No but thanks. Didn't even think of that.
Saved myself $300 today. Took relay apart, cleaned circuit board and worked my magic. Then mounted it correctly this time, not weep hole side up like dealer did. Works perfect again.
25026SFL (A61569)
25026SFL (A61569)
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A61166)
New/Unused...
JOHN DEERE 6700 SPRAYER TOW BAR (A62131)
JOHN DEERE 6700...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
(24) Ratchet Tie Down with Toolbox (A61166)
(24) Ratchet Tie...
Metal Bigfoot Lawn Art (A61569)
Metal Bigfoot Lawn...
