Tell me about your induction stove!
/ Tell me about your induction stove! #41
Our induction does a wok pretty well but some "professional" chefs are nuts about cooking power. In a previous house we had a cooktop with, if I remember correctly, a 50,000 btu burner. The required vent fan was so high powered we remote mounted it above the garage. Crazy and totally unnecessary.
/ Tell me about your induction stove! #42
My guess is WOK cooking or Asian style dishes don't transfer to Induction?
You only heat what is more or less directly against the flat cooktop. So you can heat up a wok if it has a big flat area on bottom and enough mass to carry it up. But yeah, no big fireball to torch the whole sides of it.
/ Tell me about your induction stove! #43
Check your code. The International Residential Code -- which Oregon has adopted -- only requires makeup air if there are combustion appliances in the house. If the house is all-electric you don't need makeup air.
Yes you're right. I was going by what contractors are telling me. The code says both combustion and exhaust > 400 cfm, and they were telling me > 400 cfm. (M1503.6 for those who want to look it up)
In any case I want the make up air for the 1200 cfm stove vent so the wood stove doesn't spill smoke into the room if I open the door when the fan is on.
/ Tell me about your induction stove! #45
We are installing an SKS 36” induction cooktop in our new build-one of the reasons being I did not want to have to add a make up air fan just because of the propane cooktop we were considering-it also helped that clean up on an inductive is so much easier than a gas cooktop.
Interestingly enough the air handler system installed as part of our heating/cooling system has an automatic whole house fresh air ventilation function-to address the code requirement for fresh air exchange in these new ‘tight’ houses. It is a pretty nice system, wholly automatic using some algorithms based on house size to control when it brings in outside air which it then runs through the air handlers. It is also manually controlled.
/ Tell me about your induction stove! #46
Yes you do!
One day my mother was visiting and encouraged my wife and I to go out and leave the kids with her for the evening
we came home and the house was absolutely thick with wood smoke, I thought the house was on fire
she had burned something in the kitchen, so turned on the whole house fan to help dissipate that smoke more quickly
and that suction pulled smoke from the old wood stove we had at the time and she couldn't put 2&2 together and turn the damn fan off
/ Tell me about your induction stove! #47
Are you all electric?
Homes are tighter now but being tighter has the potential to decrease indoor air quality.
The old 1930's Wedgewood Gas/Wood kitchen stove I have will outlast us all on quality...
The Wood side and the Gas Oven side well vented... Cook top gas burners vent to inside as there is no hood...
Has friends buy a home with Induction decades ago and pulled it for gas... she is a professional Chef and at home the Induction didn't do it for her....
Yep, all electric. We decided not to get an LP Gas tank, so we have a geothermal heat pump with the tubes buried in the horse pasture behind the house. I wouldn't mind gas but with the hassle of running gas lines and getting an LP tank with the higher cost to use LP, it didn't make sense. Geothermal was considerably less expensive when we had installed about 15 years ago than it is now.
So a week in with our induction cooktop and I think I am really liking it. I have only cooked a few things, but so far so good. We went with the LG 6.3 Smart Induction range. The bigger one with 5 eyes.
I really like the adjustability of it. These observations come after using an older glass top electric for 9 years. Yesterday I was browning some beef and I could tell an immediate change in eye temperature when I turned it down a notch. I could here the change in sound confirming a slightly lower heat and a noticeable decrease in cooking intensity. And with 9 or 10 different setting per dial I am sure I will be able to find a setting to suit most cooking requirements.
I also like the speed at which it boils water, faster than I am used to.
Also, I could feel a distinct lack of heat coming from the cooktop as I was simultaneously boiling a large pot of water and browning meat.
This range has tons of options that I need to investigate and try to implement into life. Yes there are "smart" capabilities and I will look into those. But I really want to learn about and use the technology that makes this range heads and shoulders better than my old one. Basically I want to use this range to it's full capabilities.
Only real drawback is a bit of a humming noise when it is turned on, but I think that is a characteristic of all induction stoves. With the other cooking back ground noise it is barely perceptible.
/ Tell me about your induction stove! #49
Yeah, different combinations of burner settings on my Whirpool induction cooktop can produce some very strange robotic squelching noises. Not very loud, or annoying, but its weird. One burner at a time, nothing remarkable, but get three of them on different settings, and it could be the backing track for a techno song.
Huh, I hadn't thought about that. Didn't notice the different tones, but the background noise was such that I couldn't even really hear the buzzing.
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
2008 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2008 JLG 600S...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
