dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,594
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I considered induction but was a bit ahead of the curve on those so went gas and no regrets. The air quality stuff is indeed leftist propaganda, and you can tell by how it suddenly started to appear at the same time as the leftists ramped up the war on fossil fuels. But here is the key, gas or otherwise: ALL stoves need ventilation to the exterior. If you have it and use it, you will be far better off in all cases as all open cooking processes generate fumes, some more than others. This is very important for indoor air quality.
So don't forget exterior ventilation with your induction stove, and watch to make sure in case you need make-up air for it with higher cfm exhausts. That was also something that was harder to do when i built than it is now. I ended up rolling my own system to help ensure our woodstove doesn't backdraft due to the stove hood. There are 3 things in our house that are not sealed: stove hood, clothes dryer and Master bath fan (well 4 if you count the woodstove...). If you run all 3 at once when sealed up in the winter, odds are you will get backdrafting and it SUX! The make up air opens a damper and runs the furnace fan to draw in exterior air to help compensate. Even then, with the wrong weather patterns it can rarely back draft...
