2660 cab tractor remotes
/ 2660 cab tractor remotes #1
Walter L
Gold Member
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
I have a 2022 Mahindra 2660 built by TYM with one rear remote and i would like to add another to have two remotes anyone have any idea where i could try to find the factory type remotes for a cab tractor. Wondering if maybe TYM might fit.
I have tried on google nothing so far in stock.
/ 2660 cab tractor remotes #2
Besides you should still be able to get them at your Mahindra dealer, yes the TYM valves should be the same.
Or just add a diverter and use the same valve-controls and add as many sets of couplers that you may need.
Right now I think that Summit probably has the best deal for diverters.
Thanks for the info, i have tried googling dealer and have not found one yet that can help, did find some info on the 2655 that would work but was not for the cab tractor which uses a different hook up on the controls and the dealer could not help any further,could not find a TYM so far that was any help.
/ 2660 cab tractor remotes #4
Try Jordan Sales, or Bills Tractors. Two good dealers, very helpful.
I am thinking about going another way by using tractorinnovation remote hydraulic kit to be able to use my loader control to operate my grapple when i need it, check them out i really like Andys kit and especially the ease of installation. Just what i needed.
/ 2660 cab tractor remotes #6
This will work with your cab tractor? It sure does not look like it to me.
Where you are located, you really should try Jordan Sales, or Bills Tractors as already recommended and go with OEM stuff.
Good luck with this. ;)
Im in north Louisiana, i have decided to go another way as posted above but thank you for the suggestion.
Will be installing the kit tomorrow.
This is what the kit looks like installed from tractor innovations at a cost of $625 tax shipping total cost,it is connected to the dump curl cylinders only and Andy with TI is great to work with if you have trouble installing. I love the price and simplicity of this kit, it does the job without breaking the bank.
/ 2660 cab tractor remotes #12
Glad that it worked for you. I do have a concern for the amount of heat that is going to add inside the cab tho.
Thank you Engineer for the comment but can you explain how it will add heat to the cab?
/ 2660 cab tractor remotes #14
How do you add a second rear factory remote? Does it just stack on top of the existing valve?
No instead of placing the
just install the hydraulic quick connector to the rear instead of the front of loader, go look at one of his u tubes then you can see how simple it is.
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
