Finally purchased after 1 year search
/ Finally purchased after 1 year search #11
The bell crank on mine is cracked so near failure. If it breaks you are left with no brakes.
I am certain of one thing if mine is part of the recall, the dealer was not supposed to sell it to me. I had even asked if it was one of the recall machines and was told it was not on the list. I am going to check with John Deere tomorrow and confirm before I get to upset about it. What year is yours?
/ Finally purchased after 1 year search #13
That is a nice, small tractor. I just finished helping a friend do some maintenance on his 1025R. I had to watch a couple of YouTube videos to find the front zerk on the upper driveshaft - it isn't exactly conveniently placed and the manual is not clear on that point!
/ Finally purchased after 1 year search #14
My 2025r is a 2019. Somewhere around the years yours was made JD switched from a Yanmar made to a tractor that was JD made with a Yanmar engine.
Yes, that front zerk is famous
On YouTube for being difficult. I have a whole section of YouTube videos on greasing, especially the front zerk. I have not watched them all yet, but I will before my first grease job. Thanks
/ Finally purchased after 1 year search #16
I have greased the front zerk on mine several times on mine. It might take me 2 minutes to do it or 10 minutes. No matter how long it takes it always seems longer. A battery grease gun helps a lot.
It’s hard to describe but you’ll understand when you go to do it. I go through a slot behind the hole you’re suppose to use. There are some hoses in this slot you can move out of the way, I then use the hole as a viewing port. You can turn the driveshaft by turning the engine flywheel to get the u joint in the correct position.
Thanks for the tip. I always grease my other tractor, but I hated it. Greasing is the worst thing for me, but I will do it. Battery grease gun is going to be an absolute must have item
Great tractor, but be careful with the mechanical grapple.
I am strongly considering a 511 grill guard after a post about a broken hood. Hate to spend 400 to 500 but might be worth it. I do pick up lots of limbs and brush.
Update: Tornado hit my camp in March of this year more than 60 large trees down. I can't tell you how happy I am with my grapple, 511 grill guard and backup mirror .
This tractor with the JD hook and pin system allows me to change bucket to grapple in less than 10 minutes. The grill guard and backup mirror have been a life saver. I had a 50,000 pound track hoe come in and do the bulk work. But there was so much small stuff , limbs metal, part of a building that I used my tractor to clean up . It may break but if it does I will repair it or buy something else. Right now I am as happy as I can be with this purchase.
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
CATERPILLAR 924F WHEEL LOADER (A59823)
CATERPILLAR 924F...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2011 WESTERN STAR  4900 SB (A60736)
2011 WESTERN STAR...
