F3990 vs newer F3710 4wd front deck mowers
   / F3990 vs newer F3710 4wd front deck mowers
I use to have a ZD1211 72RD & it overheated bad too in dry conditions.
I learned to reach behind me & rake the clippings off the screen behind seat while mowing & it helped.
I mow 4-6hrs at a time 2&3 times a week & don’t have time to stop & dump radiator screen :mad:
My current 72SD will overheat too in dry conditions but not near as often as the RD
… I traded in for a Hustler 104 Air Cooled Gas engine and it never overheated.
Was clippings dispersed evenly with the 104 RD Deck in heavy grass ?
I wanted one but not with a gas engine.
   / F3990 vs newer F3710 4wd front deck mowers #163
My ONLY comment is. glad I have a side discharge deck on my F series. Overheating is never an issue. Something I'd never want is a rear discharge on any mower. The shredder is ok however.
   / F3990 vs newer F3710 4wd front deck mowers #164
Yes. it actually left a nice cut - looked nice. but understand I'm mowing more like rough field. I mow at 4.0 inch high - I was probably mowing 3-4 inches off that. I liked the mower but if your ground is rough or pitchy I would not recommend a 104. to protect the mower deck belts from coming off, if either of the side decks flex up while mowing at a certain angle...it will shut down the PTO. this was a constant issue for me and I had to mow very slow so the side wings would not flex up too high. the 104 would be great for flat and smooth land...I don't have that.
Good info (y)
I too mow @ 3.75-4” height.
I’m mowing rough farm ground.
I’m not in a subdivision :D
Sounds like the 104” isn’t all that.
I just wished Kubota would offer a 84” single deck in a slightly bigger framed ZD1611 with a few more HP
…. I'm either going to swap out the RD for SD or consider trading it for a 2024 F3710 SD. I'm cutting mainly fields (not long though) and it's pretty rough ground. I found the ZD bouncy
SD deck definitely leaves a nicer finish of cut clippings in super thick grass IF side chute is removed (y)
The F3710 ride is no better as Hay Dude mentioned & definitely NOT the machine IF mowing really steep banks horizontally plus it’s 11 feet long & not ideal if you mostly do back & forth mowing passes.
IMHO. I’ve had both.
I actually hated the F3710
The tailswing will not stay strait making horizontal passes plus it’s narrower & more proned to tip over :cry:
I learned the hard way :mad:
My ZD1511 & ZD1611 are Truly Amazing Machines :love:
My ONLY comment is. glad I have a side discharge deck on my F series. Overheating is never an issue …
IF you cut super dry grass on a windy day where you’re getting covered in clippings with side chute removed : your F series will run scalding hot after 2+ hrs of mowing.
All 4 of my ZD SD & F3710 SD has & the ZD RD was way way worse.
   / F3990 vs newer F3710 4wd front deck mowers #168
Good info (y)
Kubota actually used to make a 100” deck for the F models, but they were really unpopular. I almost bought one, but it’s pretty useless on rolling ground, around trees, etc.
There’s still a few used ones out there, but I know you like brand new stuff. ;)
The only place the WAM’s are any good is really large properties with flat fields, airports, schools, etc.
They are more difficult to maintain and subject to cracks and welds because the deck is so long.
   / F3990 vs newer F3710 4wd front deck mowers #169
Never been an issue with me and my side discharge and I keep the deflector secured in the up position with a tarp strap constantly. Of course I don't mow tall grass anyway. Obviously, your situation is different than mine is.
   / F3990 vs newer F3710 4wd front deck mowers #170
Great information - interesting and very helpful. I don't want to make a panic purchase mistake. I'm disappointed with the ZD1211 overheating, but I'm slowly getting over it. Perhaps swapping the RD for a SD and give it another chance.
CASE INTERNATIONAL 183 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2024 DIGMASTER MINI EXCAVATOR (A58214)
2024 DIGMASTER...
24in excavator tooth bucket (A56435)
24in excavator...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
APPROX. 100 GALLON TOTE W/ ANTIFREEZE (A52708)
APPROX. 100 GALLON...
