Replacement Hydraulic lift cylinder
   / Replacement Hydraulic lift cylinder #1
Jzwoski
Mahindra 1626L HST
Idk how it happened, was just clearing some brush, nothing heavy or crazy. Next thing I know, I can’t tilt the grapple up and I look down to see this, a bent hydraulic lift cylinder. I have looked for a replacement and can’t seem to find one that fits. I have a Mahindra 1626L HST(2021). I have tried a 1.5” x 18” lift cylinder by magister but the pin holes are too small for the rod to go through. I am trying to avoid buying the overly priced and low quality hydraulic cylinders from Mahindra.
   / Replacement Hydraulic lift cylinder #2
That is a very long cylinder.
Have you looked at Surplus Center?
Shop by end types, bore size, rod diameter, retracted length, and throw.
Yea I looked on there earlier and couldn’t find anything.
   / Replacement Hydraulic lift cylinder #4
Hmm, just a thought.
Google the size and throw you need. Lots of places sell cylinders.
   / Replacement Hydraulic lift cylinder #5
You are going to buy a pair, right? Especially if replacing the bad one with something different.
Assuming I can find a replacement, yes.
   / Replacement Hydraulic lift cylinder #7
I'm not convinced that it needs to be a matched pair.....have to think about that. It would be nicer, no doubt. But absolutely necessary? Not sure.
Anyway, we've seen this problem before with poorly engineered loaders. It's not your fault; that type of failure is a known type of bending failure... it even has a name: "Euler Column Bending".
One solution that many manufacturers use to avoid it - and which does have to be done to both sides - is to add an relay lever between the cylinder end and the bucket.
If you do this yourself, pivot the lever about half way between the loader arm and bucket attachment points. With a relay arm, the cylinder can be shorter - which makes it stronger - and the tilting force on the bucket can be made to come at a better angle.
   / Replacement Hydraulic lift cylinder #8
Many of those places that rebuild cylinders have the ability to straighten them out. I had it done on mine.
   / Replacement Hydraulic lift cylinder #10
That is a heck of a good deal! I am bookmarking that site.
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
CAT D8 (A58214)
CAT D8 (A58214)
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
