pto tubing problem
/ pto tubing problem #1
Jeff4
Member
Lansing
JD214, Ariens EZR-1742
Hi,
One end of my PTO shaft tubing will not stay connected to the cover. I've tried epoxy, rivets and eternabond tape. Suggestions welcome!
Thanks!
Jeff
/ pto tubing problem #2
Maybe the question is, why is there so much friction that it tears away?
/ pto tubing problem #5
there are usually plastic pins that push in to hold the round cone end that covers the U joint onto the tube. usually the chains are hooked to the cone and both sections of shield should have chains that keep them from rotating. are you missing a chain so that one tube is fixed and the other rotating?
No, I have both chains and the cone is "snapped" into the U-joint.
/ pto tubing problem #8
The PTO shield should be free spinning from the shaft, many will have chains and clips to prevent the shield from rotating, some do not and will tend to spin with the PTO shaft. It is just a guard, it can be done away with and as long as the proper respect is shown to the pto shaft there will be no ill effects.
Thank you
/ pto tubing problem #10
New covers are not that much. Do some internet searching.
There are chains to both cones. One cone has the shield well attached, the other end, the shield (tube) keeps popping out of the cone. There are no chains to the shields (tubes).
/ pto tubing problem #12
I threw the one's that I had in the trash
willy
For those with a similar problem...
It looks like I was able to fix it with a zip tie (I ran the stump grinder for 2+ hours and it held up fine -- that's WAY longer than what I had tried previously).
Vintage Grease Gun (A64912)
Vintage Grease Gun...
AIR OPERATED OIL PUMP APROX 200 GALLON TANK (A67714)
AIR OPERATED OIL...
SDlanch SDLGC8 Electric Golf Cart (A64912)
SDlanch SDLGC8...
2017 FORD F550 4X2 S/A SERVICE BODY TRUCK (A67737)
2017 FORD F550 4X2...
2022 FORD F-250 XL SUPER DUTY CAB & CHASSIS (A67714)
2022 FORD F-250 XL...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
