Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,962
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
It sounds like you have a submersible pump and a tank tee with the gauge and bladder tank. Definitely get a new low-pressure cutout switch 30/50 or 40/60, and also check the pipe to the switch (you mentioned incompatible metal) - it should be 1/4" brass or a copper line with ferrules. If it's a galvanized pipe and you have heavy mineral content, that causes the corrosion and blockage you may be seeing of not maintaining pressure - (meaning the switch is slow to respond when pressure drops)
When your changing the switch and the tank is empty make sure the bladder pressure is 2-3 PSi under the cut in pressure (27-28 for 30/50 and 37-38 for 40/60)
Then adjust the switch to cut in around 32 and off at 52 or so.
