3 Point Hitch Problem
/ 3 Point Hitch Problem #1
Needmytractor
John Deere 770
I have a 1980s JD 770. The 3 point hitch rubs the tires and sway link turn buckles break if tightened enough to keep 5 foot bush-hog from rubbing tires. Is there a 'telescoping' sway link assembly available somewhere for my small tractor, like the one on Deere larger tractors, sliding metal bars with pins?
Thank you for any suggestions.
Thanks, but I have been searching the internet. It looks like there are no after market products that will fit the JD 770. I guess that's why the dealership couldn't help.
It's a terrible problem. The turn buckles are pot metal and break under pressure. I'm going to contact Deere directly and see if I get a response. Thanks again.
/ 3 Point Hitch Problem #4
Are you using a quick hitch? I think you might be able to get away with having your sway links tighter. I had the same problem with my 2520 and the ultimate solution turned out to be replacing the draft arms with a newer design that had a "dogleg" built into it to get the required clearance.
/ 3 Point Hitch Problem #5
Using some square tubing think you could make what you
need
willy
Yes, I do have a quick hitch. I had hoped it would fix the problem, it has helped a little, but I am concerned about tightening the sway links any more than I have. They break so easily!
What is the dog leg you refer to? I have researched online and cannot find a replacement for the arms on a 3 point hitch that will fit my 770.
Thanks for trying to help!
/ 3 Point Hitch Problem #7
Here is a comparison of the old (on the ground) and new (on the tractor) style of draft arms used on the 2520.
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
207270 (A52708)
207270 (A52708)
