Retaining Wall questions
/ Retaining Wall questions #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I need to build a retaining wall in my backyard so I can change my fencing around for my dogs. Phase one is about 3 feet tall, and probably 20 feet long. Nothing huge. Then Phase two will probably be about the same height, but closer to 50 feet long to create a flower bed.
I have some experience with retaining wall blocks with a lip on them, but I'm considering the type of blocks that are flat and require construction adhesive to hold them together.
As of right now, this is our top choice.
Does anybody have any experience with a brand that worked out well when doing this? I prefer PL over Liquid Nails, but I'd love to learn about another brand that is better for this.
I do a lot of tile work and I'm wondering is something like Thinset Mortar would be better then Construction Adhesive?
On the walls that I've built before, I've always used about 6 inches of Road Base Gravel under the first block. I'm not really sure what this accomplishes, but it seems like the universal agreed upon way of doing it. Would concrete be better? I've also seen where they bury the first row and build up from there. Any thoughts on what works best?
I'm leaning towards just putting landscape fabric against the inside of the blocks and not using any gravel. For 3 feet, and with gaps in every block, I don't see how gravel will help with drainage. Each blocks is designed to drain water when stacked together. The landscape fabric will be more to keep the dirt behind the blocks, then dealing with water.
Thank you
/ Retaining Wall questions #2
The gravel underneath is necessary for drainage. Compact it well in 2 inch increments or your wall will suffer.
The fabric, as you describe it, will cause the wall to fail. It will slowly but surely fill with fine sediment until it no longer passes water. You want gravel as backfill.
/ Retaining Wall questions #3
I thought gravel under the first course was to create a level base and allow some drainage. Similarly, gravel behind the wall with drain outlets prevents heavy waterlogged soil from pushing the wall over.
/ Retaining Wall questions #4
Not a lot of experience with block walls. We did have a subcontractor build a concrete retaining wall years ago following a professional engineer's design. It was maybe 10' high and shaped like an inverted T. Behind the wall they first placed a plastic egg crate looking material followed by Mirafi fabric and clean stone - then earth. At the base of the back side there was perforated plastic pipe to drain.
/ Retaining Wall questions #5
A good way to view a retaining wall is that it is a dam holding back a pool of muddy water. In rocky New England where fieldstone is readily available, a rule of thumb is that the thickness of the wall at the base be at least 2/3 of the finished height. This gives sufficient mass to resist the forces of the mud and water which is greatest at the bottom of the dam. The walls are also laid with a "batter" or leaning back so that movement of the stones will tend to make the wall vertical rather than overhung. If the stone is laid up "dry" the cracks and crevices between the stones provide an escape route for water that accumulates behind the dam.
If the wall is veneered by mortaring stones in place on the face, or as you propose, gluing up 4 x 6 x 12 concrete blocks, you will have put an impenetrable membrane against the downstream side of the dam. It is necessary to provide some relief of the building pressure that traditionally was done with "weepers", lengths of 1-1/2" or larger pipes set into the wall near the bottom. I suppose one could provide relief with a suitably sized washed stone footing or with spillways around the ends of the dam.
It may be that the 3' height will be low enough that the 5-1/2" thickness will suffice, at least for a while. I am Calvinist enough to believe that mass and drainage as 2manyrocks suggested is desirable.
/ Retaining Wall questions #6
I've used a Keystone product that can stack up to 3'. Country Manor® | Keystone Retaining Wall Systems
The gravel base that they typically say to put in is for stability, but I had a hard time compacting it evenly inside a trench! The first time I did the gravel for about 50 feet but later just poured a 3" concrete footing slightly wider than the blocks and everything is holding up fine. There is enough gaps in the blocks that water can come through but a a layer of fabric keep out the silt. This type uses a pin to keep the blocks inline and they have a cap that covers the top. Not being glued together you can alter or remove more easily in the future, I modified one area when I wanted to add steps in one section of a long run of a wall.
/ Retaining Wall questions #7
The aggregate base provides uniform bearing surface and provides resistance to sliding. The concrete does not provide the slide resistance.
Burying the first block is for slide resistance.
Gravel behind wall is for drainage and reduce lateral forces on the wall.
Mortar will change the forces on wall and it may be under designed for those forces. I typically use pl for adhesive
/ Retaining Wall questions #8
You may want to check into local building code. Based on relative height there can be anchorage or drainage requirements and railing or fence requirments.
Perhaps others will comment.
Thank you for the replies. The more I've looked into this, the more I'm rethinking it. This is going to be a very visible wall from our back porch. Kind of the main thing you will see, and we want it to have a wow factor to it.
I'm not getting that from any of the blocks I'm looking at. The original block that I linked to when posting this looked great in pictures, but didn't care for it in person. The more we looked at it, the more we hated it.
My current line of thought is building it out of cinder blocks, filling the blocks with rebar and concrete, and then installing tile on it to make it look nice. My wife thinks it's too much work, and I'll never finish it. I guess I need to finish a few things to change her mind!!!!
/ Retaining Wall questions #12
Hard to beat the look of a real stone wall if you can find enough of them and have the patience to fit them together.
Split face or rough face blocks also look better than flat face blocks, IMO, if that might work. But if you want the refined look of tile, then why not?
Rock would be the ultimate dream wall. It's just too expensive here. We don't have any rock, and it's all trucked in from Oklahoma and Arkansas.
/ Retaining Wall questions #14
/ Retaining Wall questions #15
Most retaining wall failures are related to poor drainage. Make sure to include drainage in wall.
Block wall should have concrete foundation.
I have never had good luck with exposed tile and freezing weather
/ Retaining Wall questions #16
Thank you
This may help answer some of your questions, but not sure if either brand is available near you.
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
2000 SHOP TANDEM AXLE TRANSPORT TRAILER (A65643)
2000 SHOP TANDEM...
Landhonor 10.5' Telescoping Ladder (A66408)
Landhonor 10.5'...
2002 Built Rite Utility Trailer (A66285)
2002 Built Rite...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
