Blown insulation over foam board?
/ Blown insulation over foam board? #1
Huntinguy
Member
Demokratik Republik of Washington
Iseke TX1300
My garage is attached to my house but, is per code, " fire barrier isolated " from my house.
I did not have the garage ceiling sheetrocked or insulated. I had some things I wanted added in after we moved in.
Now I need to insulate now and since the garage doors are hung and openers are in, it would be a bit of work to sheetrock.
This brings me to my question. What is the downfall to putting faced rigid foam (foil down) onto of the top of the bottom (the side opposite where the sheetrock would go) of the rafters and blowing insulation on top?
The foam would have to be strong enough to support the loose insulation, would need to be screwed down and taped. Still working this out in my mind.
There's wiring running on top of the trusses in places....
What am I missing.... besides common sense?
I am about to do something similar to my pump house.
/ Blown insulation over foam board? #2
I wouldn't sandwich the wiring under the foamboard. I'd just do the drywall on the bottom of the rafters/trusses, even if it's a little "involved". You can spray foam (cans) to seal around the opener hardware if needed. It'll support the insulation better and look better in the end also.
/ Blown insulation over foam board? #3
Have you considered having the garage door and opener taken down while the sheetrocking is being done? Of course just taking down the opener would greatly simplify the sheetrock job. Personally I wouldn't consider taking down a door by myself but removal and installation of the opener is a piece of cake.
/ Blown insulation over foam board? #4
Take down the opener? Yes maybe, if the OP can't/won't work around it. No need to take down the door, at all.
/ Blown insulation over foam board? #5
Like Roadworthy said, removing and reinstalling the opener isn't difficult. I'd take that route and drywall it.
The pole barn my BIL had built uses a heavy white plastic material fastened to the bottoms of the trusses, with insulation blown on top. There are heavier plastic straps that were installed under the white plastic for added support.
/ Blown insulation over foam board? #6
As has been discussed before, using a finished panel on the ceiling makes sense when you look at the cost and time of finishing and painting a drywall ceiling. Look at the cost of metal liner panel vs. the total cost of drywall.
I thought about drywalling the ceiling. It is not impossible to drop all the mounting hardware and putting it back. I could move all the mounting points up one hole on the hangers to compensate for the sheetrock. I do have access to a sheetrock lift.
The hard part would be clearing the floor space below. Then of course the taping... I don't like taping upside-down.
Finish pannels... never thought of that. I shall ponder that.
Originally I was going to use corrugated paels. They reflect light better and would brighten the garage more. Then I brainstormed just using foil faced rigid foam insulation boards. It seemed like a lightweight option.
I can cut channels around for the wiring.
Hmm, some things to ponder....
/ Blown insulation over foam board? #8
Dont. The foil faced Styrofoam, or atleast the 1/2" 3/4" and 1" is already really floppy/saggy; before adding the blown insulation later. If you aren't sure if you want to sheet rock; there is a good option.
Rockwool, it's denser and more "grippy" and stays in place Far better than fiberglass bat insulation. I assume you trusses are at 24" OC, with a 2x4 bottom cord; get 24" 2x4 Rockwool, and insert from the bottom, between the truss bottom cord. It's fire proof, sound deadening, insulating, and pretty easy to work around the wires/garage door rails.
The downside; cause their is always one; Rockwool is worse than fiberglass as far as itchy, and when cutting/moving/installing, you want gloves, long sleeve (disposable) cloths, and a face mask.
Once installed, that's no longer an issue.
Then, I would still either install drywall, or atleast 1x2 boards every 16" perpendicular to the trusses, below the Rockwool, before even thinking of having the top blown. Blown insulation isn't heavy, But over say a 24 ft span, 24" wide; it does add up to several pounds, all pushing down on the rockwool.
Also; the Styrofoam option, if you want to drywall in future, you are fighting all that. You would need to adjust down any cieling outlets or lights, so the "lip" is flush with the new surface of the drywall; you would need to use atleast 1-3/4" drywall screws; and I think you would be facing an uphill battle to get a nice, smooth, even, drywall finish.
/ Blown insulation over foam board? #9
How far apart are you trusses spaced from each other? Most common is 24 inches. If they are spaced 24 inches, you need 5/8's sheetrock so it doesn't sag between the trusses over time.
For my garage, I'm planning on using corrugated metal for the ceiling. I did it in my barn for our feed room and I really liked it. 12 foot long panels are easy enough to handle with a sheetrock lift, and once you install them, you are done. No taping, sanding, painting or anything else. Cost is a factor, but in my opinion, you get a better ceiling that you will never have to mess with again.
For insulation, my goal is to keep the heat out. Code is now R40 in East Texas. I went R60 in my parents garage and it was a huge improvement. R60 is just under 2 feet of blown insulation. I like Attic Cat. It doesn't itch, and you get to use the machine for free from Home Depot when you buy the insulation from them. It's an easy DIY job for two people. One in the attic to hold the hose, the other to feed the machine
Just remember, for insulation to work, you can NEVER go back into the attic. It has to look like fresh fallen snow to be the most effective.
/ Blown insulation over foam board? #10
I used steel roofing panels for my shop build (before electric - exposed conduit, or door openers went in though). You can order them to the exact length for your trusses - with a 3 or 4 inch overlap, if needed (I ordered 8' 4") I used a drywall lift to hoist 'em up.
Paul, you hit my concerns pretty well. Sag and some type of support.
Eddie and gstrom99:
What guage of roofing pannels and how did you attach them?
I like the walls. I started to do the osb as well. I am going to wait for summer to finish so I can burn and seal them. I like the look.
/ Blown insulation over foam board? #12
I put up corrugated metal for a ceiling in my house. I simply put it up against the rafters and used self tapping screws drilled it up into the rafters. More than 20 years later, it still looks good. There is one exception. The corrugated metal had, it seems like a light oil finished to it. I put it up barehanded and left fingerprints and marks all over the metal. If I were to do it again, I think cotton gloves would eliminate the problem. As far as durability and ease of install the corrugated metal was top-notch . Blown insulation on top of it and you’re done.
/ Blown insulation over foam board? #13
When I did it in my barn, I just bought what they had at Lowes. I used regular metal roofing screws to install it that are the same color as the metal.
I thought I had a better picture, but I can't find it. This shows a little of it.
When I do my garage, I'm going to go with R panels. I like the flat surface for my lights. Home Depot and Lowes are a lot more expensive them Mueller's, a company that specializes in metal buildings in my area.
The last time I bought from them, R panels where about $3 a running foot, or $1 a square foot. That's about 3 times as much money as sheetrock, but you don't have to tape it, sand it, or do anything else to it once it's installed. I'm still debating on silver or white for the ceiling. I can order it cut to any length, and I'm thinking they will be 12'4" long.
/ Blown insulation over foam board? #14
29 gauge is the standard for interior panels. Some places provide interior panels at a slightly lower price than exterior. Interior panels don't have quite the same coating but most people just use the exterior ones. They only need to be supported every 4 feet and they will never sag. For my 48 foot long pole barn, I used panels that were 12'4" also. Easy to handle with a drywall lift.
/ Blown insulation over foam board? #15
Eddie and gstrom99:
I used "standard" steel roofing panels, 29 ga. for both the ceiling and 36" wainscoating. I used the regular 1.5" roofing screws - 2 per truss on the ceiling. No sag and plenty strong. I bought it all from Menard's - a big mid-western chain.
/ Blown insulation over foam board? #16
If you go metal RIB panels, I highly suggest atleast checking with your local metal roof supplier, and get the price per foot for the panel you want. Locally, Home Depot/Ace/Lowes are probably 1.75x the price, and it's what color/length they have on hand. The local metal roof supplier, certain colors have like a $0.10/lf uncharged, but most are all the same price per LF. Think anything 16lf or less, no additional cost. Need them at 7'8"; you can order them that length, same price, ect. Only down side; 8a-4p pick up, M-F
/ Blown insulation over foam board? #17
Lots of complication on panel pricing. Around here, Menards is similar to cost of roof suppliers, but HD and Lowes are more expensive. Roof suppliers have lots more choices on colors, styles, etc and trim but have delivery charges that are high for most homeowner quantities. Fortunately, the factory is near and doing the pickup yourself saves the delivery charges.
/ Blown insulation over foam board? #18
I did what the OP of this thread was thinking about, except my garage already had R12 fiberglass batts between the trusses held in place with 6 mil plastic vapour barrier. So I added 1 inch thick Styrofoam tinfoil faced 4 x8 sheets, I first installed that white steel drop ceiling tile angle1 inch that comes in 10 ft lengths around interior perimeter of 24 x 24 garage to hold the edges of the4 x8 sheets ( tinfoil facing down) I used 2 inch screws with a few hundred plastic washers I made ( simple 1inch squares cut out of stiff plastic I found) these sheets were easy to cut around ceiling lights, garage door track, winch hooks etc. I was worried about sagging, so added spruce strapping where needed , but the tinfoil tape you get for duct work worked better. Nice and warm with wood stove and shiny tinfoil facing helps lighting. And fairly cheap to do.
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
Deere 310D Backhoe (A64047)
Deere 310D Backhoe...
