bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,518
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
It's home. They used the hydraulic top link while getting it mounted, then removed the hoses & hooked up the flail hydraulics. The top link has a pilot check valve so it holds position until live hydraulic action changes it.
View attachment 1510735View attachment 1510736
I figured out my intended DIY multiplier configuration. It will be based on a one solenoid diverter kit from Summit Hydraulics. The only additional thing needed will be a couple of 12" hoses w/ 1/2" male NPT ends. All other needed hardware (other than a bracket) is included. I can fabricate a bracket that will attach to the JD rear scv bracket. Should be, ballpark, $400 for everything.
Be careful using those notch hose holders in the top center of your second pic. They often don't allow enough slack when the cutter head is fully extended.
I've had two problems with mine so far. The first time, the hose just pulled out of the break away QR connector on the tractor. The second time, it tore the check valve off the cylinder. Cost me $80 to replace.
I now use a bungee to hold the hoses instead of the notches.
