Drainage - The Final Chapter
/ Drainage - The Final Chapter #1
HawkinsHollow
SE TN
Branson 3015R
So I have one more drainage task I need to get done before the winter rains arrive in the southeast. I need to backfill around the back door of my addition. This is a special challenge because LOTS of water, comes to this point. Essentially the entire half of our lot to the right of the driveway edge comes through that point.
My plan for this is to pour a curb (yellow line) to direct all that water into the 6" corrugated pipe that will bring the water out through the cinder block wall I will build (purple line). Luckily the slope works all the way out and down the hill to the left along the back of our screen porch. It is hard to see in the picture but the natural slope of the land is gently sloped to the left in the picture. I used 6" because in the worst of a rainstorm a LARGE volume of water moved through here. I think 6" should be enough for 98% of rain events. For the other 2% I will make an overflow gutter that runs along the garage and pour over the wall (green line). Does anyone have issue with this being corrugated? I want it to be cleanable and accessible. The 90's I got are essentially a T with one side closed. I hope to find a solution to add a clean out where that 6" comes out of the wall.
The 4" rigid is coming from the front of the house. One is a freedom drain that runs along the front and side of the house. It is perforated until the corner of the house and then solid until it joins the other pipe. The lay of the land there is such that any extra water that comes that direction will naturally drain out the corner of the house to daylight. The other 4" rigid is a surface drain from the front corner of the house that catches the gutter water from the front of the addition and the little bit of roof that is that little jog in. It is not obvious in this pic but as that 4" comes out from the corner of the cinder wall there will be a Y that will allow me to add a clean out. The upstream end of the pipe is very accessible as well. This 4" will then turn and run along the back of the house, eventually catching another surface drain from the front of the house and the gutters from the entire back of the house.
There are obviously 2 spot I will need to leave a void in that cinder block wall to allow these 2 pipes to come through. I plan on using a metal lintel under these cavities. I plan on gluing the cinder blocks together and then using Quickcrete Quikwall. You basically dry stack the blocks and then smear this stucco like substance on the wall and they hold together.
All of this water will be dumped towards the back corner of my property.
Does anyone see any issues with my plan? Questions, concerns, comments? I think it is solid, but I have learned one thing. If you want to find the chinks in the armor of any plan, post it on TBN and someone will have an issue with it :ROFLMAO:
/ Drainage - The Final Chapter #2
Is all of the pipe smooth wall interior? If so, this looks good to me. If not, swap out the corrugated with smooth wall.
Unfortunately the 6" is corrugated. I already had it, and I am not sure where to get the smooth walled corrugated locally. Can you tell me the disadvantage of using corrugated?
/ Drainage - The Final Chapter #4
Why using a T with one side close ? I would be more incline to used 2, 45 degree to make the turn smoother, that will be your bottle neck and you can't snake through a 90 degree.
Yeah, I see your point. But that is all I could find locally for 6" corrugated. Luckily the upstream intake end will allow easy access to the underground short run. And there will be ample slope to all of it, I am hoping that will keep there from being too many clogging issues.
/ Drainage - The Final Chapter #6
How many leaves and debris will come to your drain? Does not take a lot to clog a 6" line.
Heck even 18" clog regular around these part.
Oh yeah, also I was thinking of using concrete to fill the closed end of the T I am not using. It is hard to see from the pic but the 90 I am using to turn the vertical to horizontal has that closed end of the T pointed down allowing a place for water to pool. I plan on filling that void with concrete so water cannot accumulate there. I supposed I could do that where it turns the corners too.
Well I will have a strainer on the end. But really not that much will come that way. The water moves in sheets and doesn't bring a lot of material with it. What does come that way will be caught by the stainer. I will walk by that strainer numerous times a day so when it gets leaves in it I will notice immediately, and be able to clean it.
/ Drainage - The Final Chapter #9
The last pipe I priced,, there was little difference in price of corrugated and plastic sewer pipe.
(That was comparing 4 inch)
I have switched to the smooth interior pipe
WHY??
The corrugations catch and hold leaves, and sticks.
You will get clogs 20X as often with corrugated.
I had a guy re-do culverts on my driveway, 15" and 18"
He REFUSED to install the corrugated pipe,
The pipe we used is corrugated on the outside, but, it is double wall
The second wall inside is smooth,
He said he had too many complaints about clogs, with pipe that is corrugated inside.
/ Drainage - The Final Chapter #10
(y)
I get a huge volume of leaves and stuff from the hills all around. Nothing but trees as far as you can see....
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
John Deere 5045E for sale
John Deere 5045E...
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
