Intimidator EV Lithium upgrade
/ Intimidator EV Lithium upgrade #1
millsan1
Gold Member
Riegelsville, PA
Mahindra 2538 Cab, Volvo ECR40D Excavator
Hey all.
Just thought I would share a project I recently completed.
I have an Intimidator EV Classic. It's a great machine, but with the one big drawback of the range. I was lucky to get 9 miles out of it, and if working hard, I might only get 5. The machine weighs 2000 lbs, and is super capable.
One of the challenges that has been standing in the way of switching to Lithium batteries is the large amp draw that a heavy UTV like this can pull. Many golf carts have been upgraded to Lithium, but they generally are a lot smaller, lighter, and have much lower amp draw. 200 Amp controller is fairly normal for a golf cart, and my sxs has a 650 amp controller, pushing a 30 hp motor. That equates to over 500 amp draw, probably closer to 550 with conversion losses etc.
Up until recently, it was normal to replace your golf cart batteries with 12V lithium batteries, and the amp draw would be OK for lighter vehicles. For mine, there was not a solution that would really work.
Big Battery has a solution that works really well. They sell a 48 volt battery, that is capable of a constant 80 Amp discharge rating, and a peak of 180 Amp, for 6 seconds, and is almost a direct drop in for the 6 volt Trojan batteries I had in my sxs (within 1/8 inch in most dimensions). The kit in the link is 4 batteries, which can provide 320 Amps continuous, and 720 for a spike, when hooked in parallel. That should have met my needs , but I would have had to be judicious with the throttle. Upgrading to 8 total batteries gives me all I need. 8 batteries in parallel gives me 640 Amp constant and 1440 for peak. Perfect. As an added bonus, the energy available to me would more than double my range. A side benefit is reducing weight by about 200 lbs due to the lighter batteries.
Total price was ~$5500.
After everything was received, work started.
First step was to remove the Lead Acid batteries. Disconnected all the cables, remove the battery holders, and pull out the batteries. Simple, but those were heavy.
Next I needed to mount the charger and the bus bar, where all batteries connect to. Charger went in on the passenger side, on the rear firewall. This is right next to the stock charger port. I eventually cut the cord for the standard charger, and wired in the new charger.
The bus bar mounted on the driver's side, rear wheel well.
The batteries sit like this: 1 front to back, on the outside, then 3 left to right, stacked next to each other. This is repeated on both sides.
The battery holders needed to be modified slightly, with a little grinding and bending. The 3 batteries are about 3/16" wider than the holder, so I bent the ears a bit. Also, these batteries are connected using a forklift type plugs, on the side, so I had to cut the holders to make room for that, and there is a breaker and display on each battery, again, a little cutting and grinding to make room. The single battery holders just needed to be cut and ground to make room for the connector and breakers.
One of the tricky bits is that the motor is offset towards the driver's side. Through trial and error, I learned I needed to connect the plugs to the batteries before dropping them in. There is also limited space to cleanly wire manage the cables. So protect them, I double or triple loomed the cables. I put 1/4" loom over each cable, then put 3/4" loom over the two cables with loom on them already. Where the cables might rub a sharp area, I added a third loom of 1".
As a side note, one of the great things about working with Lithium batteries, is that they come with circuit breakers, so I could kill the power, and work with wires, without worrying about causing a short, etc.
I dropped in the batteries on the passenger side, and that has plenty of room. I still double loomed those, just to be safe. Also mounted the connector for the charger. There is a stock cable that runs from one battery bank to another. That was used to connect the controller to the negative side of the bus bar. The positive side of the bus bar connects to the stock location for the fuse and relay for the controller.
There are three wires that needed to be extended to the bus bar, two for the stock charger (which I replaced with a 2000 watt inverter) and one other for the ground for the onboard 48 to 12 inverters.
Everything was home run to the bus bar and wire managed.
I then removed the stock charger and dropped in the inverter and connected the wires.
Next I ran the voltmeter to the dash.
Final install (kinda, I loomed and cleaned up after this) of batteries etc
Double checked everything, and viola! It worked as advertised.
I ran the sxs gently at first, just to make sure it all worked, then harder, and finally pushed it as hard as I could (steep hill, high gear, 4x4 engaged) and no issues at all. Machine is definitely snappier, but top speed is not increased, but that is expected, since the top speed is controlled by a controller setting.
I then braved out into the wide world for a run down to the local deli. Machine ran flawlessly and after a round trip of 12+ miles, through some large elevation changes, I came back home with at least 50% charge remaining. Lithium are hard to get an accurate discharge on, but in my case 52.8 volts = 70% charge and 52.4 volts = 40% charge. I returned with 52.7, so less than 70%, but more than 40%,so I'm calling it 50% to be conservative.
This upgrade completely changed the machine and my enjoyment of it. I used ot get serious range anxiety and was afraid to go very far or work all day. Super happy with the results.
/ Intimidator EV Lithium upgrade #3
Cost was not cheap though. But without the upgrade it made it next to useless. That alone makes the upgrade worth the bucks spent. IMO
/ Intimidator EV Lithium upgrade #4
Any update? Any more tips for doing the change to lithium?
/ Intimidator EV Lithium upgrade #5
I,too,used lithium batteries from Big Battery to replace the worn-out lead acid batteries in my Polaris Ranger EV. Well worth it for many reasons. I did find that the included SOC (state of charge) meter was worthless, with lithium batteries one needs a "coulomb counter" type meter for useful results. I have a voltmeter and just rely on it and knowing what the battery voltage means in terms of available capacity. I really like that they use Anderson style (forklift) connectors, makes disconnecting them for service a breeze. I use electrical contact grease on all the connections, can't hurt with connections exposed to outdoors conditions.
/ Intimidator EV Lithium upgrade #6
I did the swap-out from Big Battery. Thanks for the pointer!
I am now getting "Throttle Wiper High (Code 41)". The Curtis manual says "Throttle pot wiper (pin 16) voltage is higher than the high fault threshold. (can be changed with the VCL function Setup_Pot_Faults()).
Has anyone seen this? I can't get the thing to move at all. I don't really want to invest in the VCL tool just to change this one setting.
/ Intimidator EV Lithium upgrade #7
I've been lucky, I suppose, in that I haven't got any codes, etc. due to lithium battery upgrade. There have been a few times the EV just wouldn't go, after a full charge. When that has happened, I power-cycle it, that works so far. Once, I just left the headlights on for a short while to bleed off some voltage. I didn't change any other aspect of the wiring, etc., other than to just swap the lithiums for the FLA batteries, although, if I remember correctly, there was one connection to tap 12v from a single battery (pink wire?) that I just left unconnected. The other minor change was to insert a "sampler" resistor for a coulomb counter meter to keep tabs on actual State-of-Charge. With lithium batteries, just monitoring voltage is nowhere near accurate enough to not get stuck somewhere, out of charge. I left the original charger installed, except for not being hooked to the batteries. A bit of semi-useless weight, inconsequential to the removal of 500 pounds of FLA batteries, and no workaround issues that would be caused by it's removal.
Call me lazy, but it works!
/ Intimidator EV Lithium upgrade #8
Finally, after two weeks of frustration, a kind soul from Intimidator solved my problem. Turns out I missed a ground wire. It is three wires, two yellow and one black, that are crimped to a terminal lug and enclosed in a plastic harness going up to the front.
This lug with the three wires just needs to go to the negative battery terminal that also has a short cable into the controller.
Problem solved. Thanks, Dave! Hope this might help other people.
/ Intimidator EV Lithium upgrade #9
Any updates after a few years? I want to replace my Intimidator batteries with Li.Do you think Big Battery was/is still the best choice?
I am in Maine, so self-heating batteries are really important. Any issues with yours?
Did you get a more powerful (240 V) charger? Any recommendations? I am thinking of putting in a 120V on-board since it could be charging at three different locations, and putting in an off-vehicle charger at the only location with 240.
/ Intimidator EV Lithium upgrade #10
I wonder if sodium-based battery chemistries will soon be available for this. I'm just starting to see them in batery jump boxes and coupled with an inverter in battery backup power solutions They can take the cold much better than lithium.
The sodium based batteries are heavier than lithium-ion, but lighter than lead-acid.
