75% of truck owners tow 1/year or less?
   / 75% of truck owners tow 1/year or less? #301
Those drop-in liners are evil, I think.
Aside from stuff sliding all over the place, which is just an inconvenience, the paint damage and rust issues they tend to cause is bad.
The rust is the worst, the water build up between the bed and the liner...
   / 75% of truck owners tow 1/year or less? #304
As long as the weep holes are clear don't see how a liner can cause rust.
They can do it in two ways, usually in combination. First the liner can wear the paint off, and moisture stays trapped between the bed and liner.
But I suppose that if the rest of the vehicle rusts just as quickly, the hidden corrosion under the liner is no big deal.
   / 75% of truck owners tow 1/year or less? #305
I've retired several trucks due to rust, and not a one of them was in the bed interior. In fact, I can't recall a situation where it was anywhere other than from under fenders or inside door corners, working its way from inside out.
   / 75% of truck owners tow 1/year or less? #306
I bought a dual rear wheel p/u truck new in 2001. Today, it has 79,000 miles. When it's used, it has hauled tons of fertilizer, 3600 pounds of concrete block (One), GN horse & flatbed trailer, fuel tanks, firewood, etc. Only the truck can transport these items. As a grocery getter, it sucks ... fuel 8.1 liter gas engine is very thirsty. Didn't go diesel because of the low mile usage. Glad I did. Today's diesels are burdened with EPA controls.
   / 75% of truck owners tow 1/year or less? #307
You wouldn’t have had today’s diesel though
   / 75% of truck owners tow 1/year or less? #308
Can be a PITA to cut holes in them so they don't cover up the factory bed hooks
The liners we've been getting in our company trucks have holes cut to accommodate the bed hooks. IMG_20241007_165633249.jpgMy Colorado has a rubber mat, which I need to take out and clean before winter. I also inherited a couple of spring loaded shower rods from my father which work well between the sides of the bed to keep fuel cans and other items from sliding around.IMG_20241007_165718789_HDR.jpg
I know they make something for the same purpose but these were free!
   / 75% of truck owners tow 1/year or less? #310
They rely on being the lowest point. Are they when you’re parked on an incline? No.
The surface tension of water also allows plenty of water to hang on the underside of the liner where it’s not in contact with the bed, and later drip to a non-draining area.
Weep holes also very frequently either bridge water drainage, or get completely blocked by pine needles, dirt, sawdust, etc..
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
CATERPILLAR 140M VHP MOTORGRADER (A51242)
CATERPILLAR 140M...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
