17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up.
I have a 4075R making the exact same noise. The problem is it doesn't do it all the time so it is difficult to find. It is currently at the dealer for this issue. They replaced the front differential. The rock shaft cylinder was scored,
I have a 4075R making the exact same noise only worse. It is currently at the dealer for this issue. They replaced the entire front differential. It also had a scored rock shaft cylinder. After they get it fixed they can drive it and see if the front end was the problem. I will be following this post for sure. I hope it's not the main hydro pump, they already replaced the utility pump when I first got it. Thanks John
This is a concerning situation, as we're now facing a backlog of work due to the 4075R's delayed arrival and issues.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #12
It wouldn't hurt to have your dealer check on the front differential problem. My dealer has already replaced four, counting mine. It is difficult to find this problem because it has to be moving to hear it. The tech came over for the drive shaft sleeve replacement, took it for a drive and I could hear it 400 yards away coming down the road!
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #13
I got to the dealer very late yesterday evening with the tractor. But they waited for me; after driving the tractor, they, like myself, had no idea where the noise was coming from. I also told them about the loader, and they responded that they would check the specs.
Kromc5 if it's not to much trouble I would be very interested in what your dealer finds out. Mine has been at the dealer going on three weeks, still no word on the problem thanks John
I will update the thread on what they find; I hope it's not three weeks. Our driveway is damaged, trees are down, and the storm has blown some gates off the hinges.
The dealer has not responded yet; I was contacted by JD CCMS out of Idaho today, and they are going to contact the dealer.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #16
Thanks for the update and hope you get it fixed. They got mine back together today and we're going to take it for a test run. Must not have went well, they didn't deliver it🄓
I hope that it is fixed. It would be interesting to see what they have done.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #18
Maybe between the two of us we will get it figured out! When my tractor was delivered it already had 12 hours? Upon start up it sounded normal. After a couple minutes it acted like it came under a heavy load, it was twice as loud. I pointed this out to the tech, he just shrugged his shoulders and said I don't know. After my first episode of this terrible noise it no longer did it. Makes me think hydro pump.
I just got back from the dealer. They stated the sounds were due to the rear driveline shield being installed improperly. The bad part is that the hydraulic pump is not functioning correctly, and they may also have to replace the pump manifold behind the fuel tank. However, I will
ask for a copy of the repair work and upload a scan.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #20
I am not sure what a rear drive line shield is, my front drive shaft shield got replaced and it didn't help the noise. Thanks for the update I will be watching. No word from my dealer. I usually have to call them. I don't want to be a pain in the arse.
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
Ammco Brake Machine (A55758)
Ammco Brake...
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
(2) 15x6 Wheels and Tires (A54865)
(2) 15x6 Wheels...
