Synthetic Winch Rope for Forestry Winch
   / Synthetic Winch Rope for Forestry Winch #21
IMO, if you have to handle it, this is where rope shines because of no sharp edges and being lighter, but I suspect wire cable will be less problematic over its lifetime for winching trees out of the woods unless you kink it.
   / Synthetic Winch Rope for Forestry Winch #22
We call those frayed strands of steel cable "meat hooks" in sailing. We get them on wire halyards and shrouds, and they're usually covered in a bit of dried blood and skin of the crew that preceded you. :D
   / Synthetic Winch Rope for Forestry Winch #23
The poly strap on our machine
   / Synthetic Winch Rope for Forestry Winch #24
A flat strap winds straight onto the winch, as one would imagine? If so, it makes your winch a lot weaker when the reach is short, versus when the reach is long.
If used for skidding longs, in situations where tire traction is sufficient to keep the vehicle planted, this might mean running out of pull strength as the log gets close on a smaller winch.
   / Synthetic Winch Rope for Forestry Winch #25
There is just 10ft on it and its real job is plow lift. If I need to winch something further away, I have a poly tow rope in the tool box as an extension. Haven't used it yet.
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2014 REMOLQUES DEL NORTE 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 REMOLQUES DEL...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A58018)
2017 VOLVO VNL64T...
2016 Cadillac CTS (A56859)
2016 Cadillac CTS...
