Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,676
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I did exactly as ruffdog did and for the same reasoning but it turned out that it was not the best way for my set up. It was fine for slowing down the implement adjustment speed to a nice manageable rate when the blade or grapple was on the ground and gravity was not a factor. Where I had trouble was when a heavy implement was raised off the ground, say a winch with a load of logs hanging on it or my heavy land plane. When there was a lot of weight like that the restrictor at the welded end would hold back fluid but the ram would move quicker so that a vacuum would be drawn in the restricted chamber. It would then act as if there was air in it until I cycled it a couple times. Putting the restrictor on the ram end prevented that from happening and gave my the same slow control I had before. Just my experience.....
gg
gg
