Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,001
I installed new TnT hoses the other day. It is pretty tight behind the L3010. I crushed the hoses with the back of the winch because it was leaning back to far when raised. This forced a destructive severe radius in the hoses. It was the second time I did this so I put some 90* elbows in the lines this time. Can't happen again.....knock on wood.
I already had a pretty tight bend to start with -
Now I have this. The winch will hit the saw box before it touches the hoses. There is no reason to have the top link that short with the winch on but life happens ???
gg
   / Tractors and wood! Show your pics #24,002
Perfect Mr. Gordon...I've got a similar rats nest on my remotes.
You have me thinking now...need to find a proper hydraulics parts shop nearby...
   / Tractors and wood! Show your pics #24,003
You have me thinking now...need to find a proper hydraulics parts shop nearby...View attachment 1264503
Nyco in Souderton does nice work, but I'm not really sure how far west you are.
   / Tractors and wood! Show your pics #24,004
Thanks for that Mr. Winterdeere. Fold PA in half and I'm at the fold up in the wilds above Williamsport. I'm on the most northern edge, 1/2 mile from the NY border.
Souderton looks to be 3.5 hrs away, but surprisingly, I get down to that area. Very helpful!
   / Tractors and wood! Show your pics #24,005
Beautiful country, up there. I've been thru Williamsport before, on my way to/from New York. Really liked the area, but at least back when I was traveling that route, very few tech jobs to be had out there.
   / Tractors and wood! Show your pics #24,007
More tractor-assisted dead tree demolition yesterday. Two dead elms on the west side of my evaporation pond. The one on the left (center of picture) was leaning way back towards west (away from camera in first pic, second pic shows lean).
Problem is, I wanted that tree to fall to the right (first pic). My original plan was to climb up to the three stems and cut them off to relieve some of the weight helping it to lean the wrong way. After getting up there, I couldn't really get to the "top side" of the tree and cutting the branches off while hanging under them is not a terribly good plan :).
So no cutting while climbing, but did get a photo (fourth pic) back towards the tractor, showing the direction I would be pulling from. Now, the plan was to drop the tree on the right (first pic) then the one on the left with tractor pulling as described above.
Due to the heavy back lean on that tree, I was a little unsure how much tension would be required from the tractor, or even it I would be able to overcome the lean at all. If the tree accidentally fell toward the lean, it wouldn't be the end of the world, just would have been a little harder to clean up, so I decided to go for it.
I dropped the right tree first, which was already leaning toward the uphill side of the evaporation pond, i.e., right where I wanted it to go. Then attached my pull rope right above the first crotch on the left tree and applied some tension with the 2520. The plan for this one was to cut the tree up, then go pull it over (if possible).
So, I got it cut up as much as I dared (leaving about a 2" hinge, then, I saw the tree start moving. Dropped the saw and ran toward the tractor, thinking I would start applying some more tension to guide it. However, the tree just kept on going and fell exactly where I wanted it, i.e., right on top of the other one. Now just need to buck it up and chip the small stuff.
I think one of the more interesting things about this project was having to pull at 90 degrees to get the tree to go where I wanted.
Edit: NOTE: This is kind of funny, the only thing I was really concerned about the trees hitting was that white PVC pipe sticking out of the side of the hill, which is the output from my aerobic sewage treatment system. If you blow up pic of the trees on the ground, you will see that I stacked several 4 x 4's on each side of the pipe to protect it. Also notice that, with all the mayhem going on around it, neither of the trees actually hit the pipe or 4 x 4's.
   / Tractors and wood! Show your pics #24,008
I've been thinking of adding restrictors to my 3rd function hoses because the flow is not controllable. It is either full on or full off and that is an issue when using some of my front mount implements. Question is, do I need to put the restrictors on both of the 3rd function lines or just one?
   / Tractors and wood! Show your pics #24,009
Well my picture is not as interesting as Runner, but everything went as planned for the head gasket replacement and tractor has been back at work for the last week running great thanks to Scott ( master diesel mechanic)!👍🏻☮️✌🏻
150+ pieces per trip to the shed!
   / Tractors and wood! Show your pics #24,010
On my grapple, I installed one simple orifice restrictor in the line supplying the rod-less end of the cylinder. As a cylinder moves, the rod-less end flows more fluid because that end has more fluid volume. Why not install the restrictor in the side that is flowing the most fluid?
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
WB 36" PIN ON DITCHER BUCKET (A52707)
WB 36" PIN ON...
2019 Deere 35G (A53317)
2019 Deere 35G...
2001 CATERPILLAR CP-563D PADFOOT ROLLER (A52707)
2001 CATERPILLAR...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
Electric Mobility Scooter (A51694)
Electric Mobility...
