Aftermarket Spindles?
/ Aftermarket Spindles? #1
71 RAT
Deerfield NH.
FORD 821
Hello folks,
Really hate having my 821 down, she needs some well deserved maintaince. Was just replacing tires, currently at the spindle bushings and thrust bearings. The spindles are in realy rough shape. Finding good used will probably be a nightmare, aftermarket seem almost to cheap!
Anybody have experience with the aftermarket replacements? Good or bad? BTW tractor has a loader, and I use it, not a show piece. $50ish-$70ish the A&I brand are $17ish??
Thanks
JKW
/ Aftermarket Spindles? #4
I am not using these because I have an 8N. But, the founder and his son are friends of mine and I have done a ton of business with them over the past 30 years. They do restorations and refurbishments and use the parts they sell. I would encourage you to call on Monday (feel free to drop my name) and talk to Derek Barkley, the son and current owner. I am sure he will tell you that he uses these spindles in his restoration work and they should be the same as you would have gotten from the factory.
Thanks again for your input and time. I'll check it out!
I'll check them out! Thanks again Ed!
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
