Should I Replace Hoses While Accessible?
/ Should I Replace Hoses While Accessible? #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
These are backhoe hoses are on a 2004 JD TLB with 600 hours use. Most of the hours were taken up by the loader, not much backhoe use. The hoses are currently removed. Two have rusty fittings but what about the others that have no apparent damage?
Cost/money is not a “big” concern here but I like to be frugal whenever possible.
What would you fellows with experience do?
/ Should I Replace Hoses While Accessible? #2
I'd worry more about the hoses than the fittings. Are the hoses showing signs of sun and age damage?
Well, the crimp on the fittings of two hoses have weakened from rust, I don’t trust them. Ironically, it was the fabric covering intended to protect the hose that caused water to be retained which caused the rust. I won’t be covering the steel fittings with protection this time. The hoses are otherwise in good condition with no wear marks, cracking, kinks and such.
I am concerned about the interior. Do hydraulic hoses deteriorate from the inside which will then contaminate the fluid and eventually leak?
/ Should I Replace Hoses While Accessible? #5
Keep in mind, that fabric covering serves a dual purpose. Yes, it protects the hose, but it also protects you from a pinhole hydraulic fluid leak, which can lead to a fatal fluid injection.
/ Should I Replace Hoses While Accessible? #6
Cheap insurance. I would replace.
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
(4) HD Pipe Gates (A66408)
(4) HD Pipe Gates...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
(4) Tires and Rims (A65640)
(4) Tires and Rims...
