Did a blue.
/ Did a blue. #1
Wannabee
Iseki Tx2160
I was removing the battery from my Iseki TX2160 when the negative lead flopped onto its battery terminal just as I bumped the positive against the metal body. This arced momentarily before I broke the circuit. Now I cannot start the tractor. Glow plugs work but starter will not turn. Please can someone advise on what I've damaged? Thank you
/ Did a blue. #2
Noticed you posted twice. If you have a volt meter and TIME, you can go thru the entire tractor electrical. From fuses, grounds, VR, alternator, starter and since it's more modern the inputs to the computer.
Or take it to a local Iseki dealer and have them go thru it all for about $1,200.
/ Did a blue. #3
I’ve never seen an Iseki dealer.
/ Did a blue. #4
He solved the problem:
Fault solved. A wire from the safety switch had a loose connection. It is very taut where it exits the side of the chassis towards the dash. I think my big boot must have caught it using the clutch pedal or getting on or off the tractor..
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2020 ISUZU NQR (A63569)
2020 ISUZU NQR...
2022 Belshe WB14 18ft Trailer (A64047)
2022 Belshe WB14...
