Removing mud wasps nests
/ Removing mud wasps nests #1
Tpondel
Gold Member
NW OHio
Deere 3033r
We have painted concrete board on the outside of the house. Occasionally, I’ll find a mud wasp nest and break it apart.
Unfortunately , there always remains a good part that sticks to the board. Anyone have idea on how to remove the last mud?
/ Removing mud wasps nests #4
Water from a Power Washer.. :D
Seriously, if you are worried a pressure washer will damage the paint, try a strong stream from a hose and/or lightly scrub with a outdoor broom and a little soap.
/ Removing mud wasps nests #6
We get them frequently under the eves of our textured vinyl siding. The remnants of the nest are indeed tough to remove. If you don't remove it all, the wasps quickly build a new nest in the same spot. I use a Rotox nozzle on my pressure washer, which does a good job. Might be tough on a painted surface though.
/ Removing mud wasps nests #8
Usually, mud-daubers get their mud supply nearby. Like the condensate drain from the A/C etc. I sprinkle a little bit of Sevin dust on those spots and it helps knock their numbers down.
Strong water stream for removing the nest remnants.
/ Removing mud wasps nests #9
I usually just rub them away. Either with my fingers, or a stiff brush. It might not get 100% of the dirt, but it's enough that it doesn't bother me anymore.
/ Removing mud wasps nests #10
Am I the only one who likes the mud wasps? We deal with so many nasty yellow jackets and bald-faced hornets, that I find the black mud wasps downright docile and entertaining. I just leave them alone, they don't seem to be a huge problem around here.
Yellow jackets are the only ones I eradicate on-sight. I hate those bastards. Other wasps and hornets are treated depending on the location they've chosen to build. For example, inside our patio umbrellas is a forbidden zone. :D
/ Removing mud wasps nests #12
No problem with Mud Daubers, but on the other hand; Yellow Jackets and Bold Face hornets get eradicated as soon as possible (unless the nest is too big... means I didn't find them in time :mad: )
/ Removing mud wasps nests #15
I've had those mud wasps fill the key hole on my tractor. Clean it out - spray it full of WD-40.
/ Removing mud wasps nests #16
I got a couple pictures and a video of this one leading a “zombie drugged” spider to the nest so it can be eaten by wasp larvae. Pretty crazy.
/ Removing mud wasps nests #17
That sounds more like a leaf cutter bee. In my experience, mud daubers (and bees) are rather particular about the size hole that they want.
All the best,
Peter
/ Removing mud wasps nests #18
Cicada Killer wasps look threatening but they have never come after me.
/ Removing mud wasps nests #19
We have a lot of those, I often find them hibernating when digging. We also have more cicadas on our property than the rest of the surrounding area, and I've never understood why. When we hit those rare double-brood years (2021?), you can't walk outside or mow the lawn without wearing a few of them.
/ Removing mud wasps nests #20
Yesterday - I killed a couple wasp like things. Smaller than a yellow jacket - totally jet black - not a bit fuzzy or hairy. First time I've seen these things.
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A61165)
2016 Volvo VNL...
2012 John Deere 1770NT CCS Planter (A63109)
2012 John Deere...
1997 GMC GMT-400 SINGLE CAB TRUCK (A62130)
1997 GMC GMT-400...
Zero Turn Mower (A59231)
Zero Turn Mower...
2019 FREIGHTLINER CASCADIA 6X4 TANDEM AXLE SLEEPER TRACTOR (A59909)
2019 FREIGHTLINER...
