TC35DA Switch Identification
/ TC35DA Switch Identification #1
DaveCQE
Member
Central Vermont
2004 Massey Ferguson GC 2310; 2004 New Holland TC35DA
Morning!
I just purchased a 2004 TC35DA and I am not sure about a few things.
  • There are two switches on the right side of the operator, one a lighted toggle, and second a switch. Not sure what either do.
  • The lever for the 4WD I am unsure if it should be forward or back for 4WD.
  • On the dash there is a black knob and switch, not sure of their operation.
  • Can someone send me the portion of the operations manual explaining all the switches, levers, knobs and such?
Any help would be appreciated, thanks!
/ TC35DA Switch Identification #2
I haven't checked recently but the NH website used to offer downloadable operators manuals for free.
Do you know the url for the NH website?
/ TC35DA Switch Identification #4
Morning!
I believe one switch is for cruise control and the other is to shift ranges. Did you flip the switches while driving? Pretty easy to figure it out.
I just got the machine yesterday, need to spend some dime figuring it out. Do you know if the 4WD lever should be forward or back for 4WD? Thanks!
/ TC35DA Switch Identification #7
Morning!
The toggle is to switch between Turtle and Rabbit for the HST transmission. Makes it a 4 range instead of a 2 range. There are also 2 buttons on the joystick to select Turtle/Rabbit. The rocker is to set the cruise control. Just push it when cruising at the speed you want. Hint - don't step on the brake or turn it off without your foot on the forward pedal, unless you have the seatbelt on. It is a sudden stop.
Forward is engaged. Mine stays in 4WD. To disengage it I sometimes have to lift the front wheels off the ground with the FEL.
The black knob is for headlights and taillights. The switch to the right of it is for the front work lights.
I would get a copy. Lots of good information on operation and maintenance. It has the wiring diagrams at the back.
Congrats on your new tractor. We really like our TC40DA. Already spent 2 hours on it today dragging the arena and smoothing out around our new hay barn foundation.
Thanks for the responses, I'm learning my way around the machine. Need to fix my neutral safety switch since about 50% of the time I have to move the range selector forward and back to find the spot where I can start the engine.
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2019 Ford Escape AWD SUV (A66738)
2019 Ford Escape...
(10) 24' Free Standing Panels (A64912)
(10) 24' Free...
2003 Bombardier Evinrude 75 Outboard Boat Motor. (A66738)
2003 Bombardier...
CAT D5N Winch (A68134)
2013 Ford F-150 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
